General messages
abarthmultijet
Post by abarthmultijet » 04 Apr 2022, 21:15
If this was your current code:
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01
Try this one:
33 32 31 35 30 30 31 34 31 35 30 4F 55 54 50 55 54 44 4A 49 54 20 15 07 11 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 42 71 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 47 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Abarth Punto Evo, Fiat Doblo 263 1.4 t-jet, Audi S4 B8.5, 1.3 Multijet specialist, Uconnect 7 specialist,
michL
Post by michL » 06 Apr 2022, 12:53
Oh my GOD :o Abarthmultijet, you are the BEST.
Many thanks.
michL
Post by michL » 06 Apr 2022, 13:02
You are thé God of the Uconnect 🙏
abarthmultijet
Post by abarthmultijet » 06 Apr 2022, 20:26
No problem, hope you are happy with it.
Try to plug in your phone, this code supports apple carplay/ android auto. If it doesn't work i know how to activate it. Send me a PM!
michaelg1234
Post by michaelg1234 » 18 Apr 2022, 10:45
Sorry to jump on this thread, I have been trying to retrofit a used unconnect 7 inch for ages but can not find any information, Is this possible and whats the procedure? please.
Retriever
Post by Retriever » 30 Dec 2022, 10:39
Hi all,
I swapped the 'UConnect 5 NAV' for a 'UConnect 7 DAB NAV' in my car (Fiat 500 0.9 TwinAir Turbo year 2016) and all functions (NAV, AppleCarPlay etc.) worked immediately.
I use the MES V 5.0 with the yellow adapter, first wanted to fix the error with the 'flashing odometer'.
Selecting Fiat 500 0.9 TwinAir Turbo / Body / CAN Setup PROXY Alignment Procedure 2014+ / Adjustments / Execute -> ends with error 'out of range....'
Can I fix 'flashing odometer' without make any adjustments to the proxy configuration?
Current config:
33 32 31 35 30 30 31 37 36 39 36 4F 55 54 50 55 54 44 4A 49 54 20 16 02 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 42 71 06 F4 20 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 68 00 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Best Regards
Retriever
Post by Retriever » 30 Dec 2022, 17:25
abarthmultijet wrote:
06 Apr 2022, 20:26
Send me a PM!
Need help too, please. How can i send an PM?
chrener
Post by chrener » 30 Dec 2022, 19:36
Try this
33 32 31 35 30 30 31 37 36 39 36 4F 55 54 50 55 54 44 4A 49 54 20 16 02 17 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 42 71 06 F4 20 1C C0 00 00 00 16 00 01 08 94 06 01 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 68 00 08 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 07 00 94 08 52 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 E0 0C 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
And after proxi alignment procedure check and share newest log file on main MES directory
Jeep Renegade 1.4 MultiAir TURBO 75th Anniversary
Retriever
Post by Retriever » 30 Dec 2022, 21:52
chrener wrote:
30 Dec 2022, 19:36
Try this
Thx a lot :-)
are youu sure, that byte 148 must be "00" and not 05 for UConnect 7 ?
chrener
Post by chrener » 31 Dec 2022, 13:11
Retriever wrote:
30 Dec 2022, 21:52
chrener wrote:
30 Dec 2022, 19:36
Try this
Thx a lot :-)
You will see after proxialignment if there must be 00 or 05 on byte 148... You can apply 05...
Also you can apply Byte 140=70
As i said after alignment check MesLog file and share it here on forum
