EXCUTE OIL CHANGE ALFA MITO 1.3 JTDM
CORSO68
Post by CORSO68 » 27 Jun 2018, 08:45
HOW CAN Y CHANGE THE WARNING OIL CHANGE
Y have a multiecuscan programme whit a ELM 327 usb
y have looking in engine ecu but dont find it
thanks
Re: EXCUTE OIL CHANGE ALFA MITO 1.3 JTDM
Post by s130 » 07 Jul 2018, 10:11
Ensure you have selected the correct ECU as there are several for this car.
Then look at the ADJUSTMENTS tab for the engine ECU. You should see the Oil Change but ONLY if your vehicle has a DPF fitted. If no DPF fitted the Oil Change Reset is not required.
