Programming Transponder/Remote Control for Fiat Grande Punto 2006
General messages
Vito95
Post by Vito95 » 04 Mar 2017, 11:55
Hi!
I'm going to buy Multiecuscan.
I would understand if it was possible to encode a new remote control and trasnponder of a Fiat Grande Punto 2006.
Tranks.
Re: Programming Transponder/Remote Control for Fiat Grande Punto 2006
Post by s130 » 05 Mar 2017, 11:44
According to MES screens for Grande Punto then it looks like it can program keys AND remotes that are RFI based.
HOWEVER I suggest you do the following:
1) Download and install MES (free version)
2) Select the Grande Punto from the list that matches your car
3) Do a Scan PF11 - this will the available modules on you car
4) From the list displayed look for the Body Computer details and make a note
5) Now on the main menu you your car select the matching Body Computer
6) Now do a Simulate PF10 connection and then go to the Adjustments Tap
7) See if Key Programming is listed and if so select this and read all the instructions on the right side of the screen window
I suggest/ask the above as there are different versions of the Grande Punto each with potentially different body computers and I have NOT checked all possible combinations for key programming support.
Vito95
Post by Vito95 » 06 Mar 2017, 18:01
The function is supported (Key programming).
In the description is written: "The keys/transponders have to be pre-programmed with body computer's secret codes in order to be recognized by the vehicle."
If you purchase a new key, virgin, I can program it entirely?
I have the secret code for programming keys.
Thanks.
franmex
Post by franmex » 18 Sep 2018, 16:04
I have the same question as the previous post :
I have tried a new key/remote with MES 4.0 Registered on my Ducato X250 2.3 Facelift ans it is nor recognized. The original key is well recognized.
The vendor of the key says that the key needs to be pre-coded, but I was thinking that MES was doing it (with the electronic code).
May we have an answer please ? Thanks !
Liam1804
Post by Liam1804 » 20 Mar 2019, 11:02
franmex wrote:
18 Sep 2018, 16:04
Did you manage to sort it? How do you pre-code a band new key transponder?
Edwardden
Post by Edwardden » 23 Mar 2019, 21:02
I try to rpogram the PLCC version of the PIC16F877A with a PLCC to DIP programmer with the melab U2 programmer but it report the device dose not match the selected device,but I can program the DIP version of the same chip,can anybody help me with this issue?
kido.resuri
Post by kido.resuri » 25 Mar 2019, 21:29
You need the dump of the body controller and a key programmer device, like zed-bull to prepare an id48 chip, so you can program it to.the car with multiecuscan.
https://www.puntonium.hu
