FESmobile 2.0 Released!!!
FESmobile - Windows Mobile version of Multiecuscan
Post by yani » 30 Jan 2012, 21:26
I released FESmobile 2.0.
Now it supports all modules which are supported in Multiecuscan 3.4.
It has improved user interface, improved Bluetooth support and improved interface support.
Now it can also work on Windows CE devices (the GPS units for example).
Robydriver
Re: FESmobile 2.0 Released!!!
Post by Robydriver » 05 Feb 2012, 23:47
yani wrote:Hi,
GREAT! :shock:
Sorry for my english.
One question:to use FESmobile 2 I must have a license of multiecuscan.
If I'll buy Multiecuscan MULTIPLEXED package,I can use the CANtieCAR interface module and its license to ability and use the FESmobile 2.0 on my phone?
Or,if the CANtieCAR interface is not compatible with Smartphone running WinMobile 6.5,I can use the license (how?) of Multiecuscan MULTIPLEXED package to ability FESmobile on my phone with a elm327 BT interface?
Thank you for your reply.
Post by yani » 06 Feb 2012, 08:28
Yes, you can use the license code from Multiecuscan MULTIPLEXED to get a License Key for FESmobile...
And you can also use the CANtieCAR interface with FESmobile but without the multiplexing capabilities. The multiplexing support is not available in FESmobile yet.
Robydriver
Post by Robydriver » 06 Feb 2012, 10:11
yani wrote:Yes, you can use the license code from Multiecuscan MULTIPLEXED to get a License Key for FESmobile...
Very good!
Thank you
meacho
Post by meacho » 07 Feb 2012, 21:14
Hellow, I have problem with installation of FESmobile 2.0 on Windows CE 6.0 (GPS) and Windows CE 4.2 to.
It allways say: The file "...\FESmobileSetup20.cab" is not a valid Windows CE file.
Do I have right file for Windows CE?
Post by yani » 08 Feb 2012, 07:08
Probably the downloaded file is corrupted. Please download the file again and try again.
meacho
Post by meacho » 08 Feb 2012, 09:54
Yeah, I thought so to, so I download this file many times, without success.
Then I unpack cab file and manually rename all files like it write in _setup.xml file.
Then I start the program and it works. So I think, that the problem is in FESMOB~1.000 file.
BR-Scan
Post by BR-Scan » 14 Feb 2012, 03:20
I'm having the same problem. It says not a valid Windows CE installation file. Please help!
Post by yani » 14 Feb 2012, 06:55
Yes, you are right. The installation CAB is not good for CE devices. I will publish a RAR release which you can simply extract into a folder and run.
BR-Scan
Post by BR-Scan » 14 Feb 2012, 10:58
Thank you Yani!
