ELM327 Problem
ELM327 Problem
Hi, I have problem with my ELM 327 and FES 3.3 trial...
The interface is correctly recognized by the system and the test is ok:
RESPONSE:
ELM327 v1.5
ELM327 v1.5
Questa interfaccia è compatibile con ELM 327 1.4! Dovrebbe collegarsi correttamente con tutti i moduli CAN.
But I can connect only at the engine's ecu, why??
If i try to connect to Service interval reset or to body can info, I have this message:
http://imageshack.us/photo/my-images/220/faultx.jpg/
This is the photo of my ELM board:
http://imageshack.us/photo/my-images/220/elm1a.jpg/
http://imageshack.us/photo/my-images/38/elm2.jpg/
My car is lancia Musa 1.3 Mjet 2005
Can anyone help me?
RESPONSE:
ELM327 v1.5
ELM327 v1.5
Can anyone help me?
- Which Version of ELM is this?
- ELM3.jpg (156.44 KiB) Viewed 11133 times
- ELM2.jpg (145.41 KiB) Viewed 11133 times
- ELM1.jpg (236.55 KiB) Viewed 11133 times
Re: ELM327 Problem
I have call the seller of the interface, he told me only remove R04 (see immage attached) from the board
Now I can connect to CAN....... I think this is V1.5 FAKE need capacitor's and resistor's??
- ELM FAKE RESISTOR.jpg (153.09 KiB) Viewed 11120 times
Re: ELM327 Problem
No, you do not need to do more.
These Interface v1.5, pin 6 + 14 R04 with this resistance
connected and that can not recognize and does not connect Multiecuscan
her.
The error with the resistor R04 R14 was also partly here already
more than once.
viewtopic.php?f=5&t=1493
her.
more than once.
Re: ELM327 Problem
hello
I just bought ELM327 and fes 3.3 to make service and proxies alignment to cars Fiat-Alfa. I had these problems: Fiat Doblo 1.9multijet : connection failed check com port-eobd. alfa brera ok, I controlled motor parameters, service and number of ECU programming. when making proxy alignment during bodycomputer data write operation it fails . ..it continues to write the device data but at the end It fail again.. test results are all ok except elm 1.3 + (? i thinking to bought 1.4 version) and latency is too high ... I do not know what to do ....(i pray to you excuse my orrid english) thankyou for aid
Re: ELM327 Problem
eutsch
Your ELM, it is a usb or bluetooth version?
Thus, there are differences in the test function
When connecting to the Fiat Doblo was asked to provide yes Specified
have set the wrong com port.
On both vehicles, the proxy service via CAN bus and read
But the data engine (ECU) ISO14230 (KWP2000)
With the ECU you get a connection?
With the proxy service or not?
Please make a screen time of
FES / settings / interface / test
Re: ELM327 Problem
ok thanks i send scan data as possible
Re: ELM327 Problem
hi eddy
the elm scan says: all ok, but the version is 1.3+ and the latency is too high. this is usb version.i dont know how to adjust the latency... the ELM seller says is impossible that the interface can be a 1.3 version .he is disposed to send me another tested 1.4 interface.I'm waiting for this
the port setting is ok as well as the clocking rate . i was able to connect FES with my brera , read all engine function,enter in all device of the car and starting the proxi alignment process .it fails while write the body computer data.what you think about?meanwhile i brought the doblo to mechanic
Re: ELM327 Problem
Please show some games will be shown in the test!
And again please, you get a connection to the engine control unit
but not to the body computer, service?
Is that right?
And you've done all settings as they are required here?
Is that right?
Re: ELM327 Problem
hi eddy i send the report of last operation to server . i dont know how to save setting pages to send them...sorry i'm not too able with pc .
Re: ELM327 Problem
The only real ELM327 from ScanTool.net will give you the real firmawre version as they are theirs ! The chinese clones (and there are quite a few it seems), shows any thing from 1.2 to 1.5 (mine says 1.5) These are irrelevant. It works or it doesn't. For the CAN, modify the interface as described somewhere else.
If it works, fine. If it doesn't and you need it, get the authentic interface.
As for the vendor opinion ? I prefer not to give my opinion about it. Let the clown send you an other clone, may be it will be from a different source and better behaved.
