Update to ELM327 compability when?
I am using a ELMCan interface with ELM 327 chipset. Reading your announcement that for an coming update Multiecuscan will also support ELM 327 it would be very intesting for me (and others as well, I suppose) when such upgrade can be expected. I´d like to use it for my car (ALFA 147) as well.
Do you have any idea when we can expect this updated version?
Thanks for your great site.
BR,
Frank
BR,
Frank
Re: Update to ELM327 compability when?
Well, my plan is to have the ELM327 support next month.
I would realy appriciate that!
Keep up the good work, big appreciation for you!
to Yani
At me car Fiat Albea of 2007 (Russia). The engine 350А1000 (1,4l, SONC). Number ECU of engine IAW5SF.MT. There is a possibility to add in your program?
- ISOcode.PNG (28.9 KiB) Viewed 8308 times
Sorry, I don't have any info for Fiat Albea yet. On the other hand I see that Punto '05 is using the same ECU IAW5SF. I will probably add support for that in a few months.VVladimirovich wrote:to Yani
anchio sono molto interessato all'utilizzo del software con elm 327 o galletto 12.50
e previsto un aggiornamento per usare questo tipo di interfacce?
grazie anticipatamente.
Hey, I really like this software, I own a ELM327 Interface, too - which advantages would the ELM327 bring compared to a normal kkl interface?
best regards
felix
best regards
felix
Vorrei sapere se ci sono novità sul utilizzo del interfaccia EML327 visto Che ne possiedo una e non posso Usare Multiecuscan
Vi ringrazio per Ogni chiarimento
1. Support for CAN protocolpowerpaul wrote:Hey, I really like this software, I own a ELM327 Interface, too - which advantages would the ELM327 bring compared to a normal kkl interface?
best regards
felix
2. Less CPU usage
nuova versione?
Disponibile quando SARÀ L'ultima versione?
e cativo Il Servizio reset?
CANbus Il Protocollo?
La Commerciale version venire acquistata potra Essere EA Che Costo?
complimenti per Il Suo Lavoro; e Davvero Ottimo Programma delle Nazioni Unite ...
Davvero complimenti.
attendo risposta.
attendo risposta.
