FESmobile demo RELEASED!!! - Windows Mobile version
FESmobile - Windows Mobile version of Multiecuscan
koCO78
Re: FESmobile demo RELEASED!!! - Windows Mobile version
Post by koCO78 » 31 May 2011, 21:49
No compatible with key based smarthphones? I tested on my old HTC S710 and can't get to the settings options also can choose the make but them the scroll is not working to chose a model ...
ryzor44fx
Post by ryzor44fx » 25 Jun 2011, 20:59
I have Panasonic Toughbook cf-p2 running on Windows mobile 2003 se and I can't install FESmobile. It's coming up with error 'The file "\SD\FESmobileSetup101.cab" is not a valid Windows CE Setup file'.Do FESmobile work on Windows mobile 2003 se?
Robydriver
Post by Robydriver » 04 Jul 2011, 15:05
Hello!
Sorry for my english
I've an HTC HD2 with WinMobile 6.5
FESmobile working,the vga patch is ok,but when I try to connect it to a veichle (with bluetooth ELM 1.3) the software doesn't conect to the veichle and freeze the phone. Reboot is needed.
The software need some specific software to work (ad es netframework xxx,or similar)?
Thank you
mino182
Post by mino182 » 15 Jul 2011, 14:15
Hi, many thanks for FESmobile. Working perfectly on Mio A501 with custom wm6.1. But I have problem with my T5388i (HTC touch diamond 2 clone with wm 6.5). This phone can't connect to ELM327 BT adapter. Bluetooth is ok, because I use it with other bluetooth devices and it works normally. Do you have some ideas? Thanks.
Robydriver
Post by Robydriver » 05 Aug 2011, 14:10
Robydriver wrote:Hello!
Thank you
Hello!
Solved!
Work great in HTC HD2 with windows mobile 6.5
The problem occourred,was my error to connect elm327 interface via BT first to launch FESmobile.
There's only need to activate BT on phone,launch FESmobile,and control to set the correct com on FESmobile settings (for HTC HD2 is com2).
Enjoy.
ps:FESmobile works on Asus a638 pda with windows mobile 5.0,too.
Post by Alfaeddy » 15 Aug 2011, 13:57
I've tried using FES Mobile on my phone to connect to my Alfa produce 156th
First I have FES installed.
Then the Bluetooth mobile phone connected to the ELM
This has everything works!
But after I start FES is the selection:
Alfa / Fiat / Lancia
when selecting the model 145 / 145'98 / 145'99 etc.
But the program gets stuck and I can not continue to select.
Can I please give a hint of what else can I do so I get to work FES
Nokia Mobile Phone
Win Mobile 6.0
Thank you for the help
meacho
Post by meacho » 25 Aug 2011, 13:35
What about support for Windows CE version of operation sistem?
It will be great to have that application on GPS sistem :D
Post by yani » 02 Sep 2011, 06:35
meacho wrote:Hello
I already have a new version of FES mobile which works on the Windows CE GPS units.
However, it will take me some time to release the new version.
meacho
Post by meacho » 03 Sep 2011, 12:45
Great, is this version available to download?
Because file FESmobileSetup101.cab is not working on my windows ce.
Thx
Post by yani » 04 Sep 2011, 07:13
meacho wrote:Great, is this version available to download?
Thx
Not yet. I'm still working on the new version.
