Closing windows with the remote key AR 147
DiReCtX
Post by DiReCtX » 04 Oct 2010, 16:42
Hi Yani if you are able to "turn on" closing windows with the remote key, because I have two AR 147 and one of them has the opportunity in the second, but you can only open the window using the remote control of a key, so I suppose that, because of the security features turned off but from experience I know that you can turn it like, for example, is VAG group
The function would certainly be very useful in other models of the Fiat group
ThX
DiReCtX
Re: Closing windows with the remote key AR 147
Post by DiReCtX » 02 Nov 2010, 21:29
Hello again Yani, I read a bit about the closing of windows in the DTE (Electronic Technical Documentation) and this feature is called "Superclosure" and that the work must be in the door seals anti-crush sensor, and are indeed, such a proposal that the function of closing windows with the remote control is off in BC so it is possible to enable this.
Thanks for replying
sa80libero
Post by sa80libero » 07 Nov 2010, 18:49
would be very useful ....
to add?
gdimassa
Post by gdimassa » 13 Nov 2010, 08:50
Any news?
bnj
Post by bnj » 25 Nov 2010, 15:00
I am interesting in purchasing Multiecuscan but the only feature that interests me is enabling the SUPERCLOSURE for Alfa 159.
Is that planned for a future version or is it even possible to be achieved via OBD - I know that the Fiat Examiner can't enable it.
bnj
Post by bnj » 01 Dec 2010, 19:43
Please, may I have an answer?
I'm not asking when if that feature will be included, I just want to know if that's even possible or not.
Post by s130 » 02 Dec 2010, 21:38
Do you know for a fact that your car (Alfa 159) hardware and software supports "superclosure"?
If so then stating which model (Version Code), year and country may help.
bnj
Post by bnj » 03 Dec 2010, 02:56
Yup. Every 159 has superclosure but for some reason (some people suspect a lawsuit) they disabled the close function for all the models built beginning with 2008. So basically you can open the windows/sunroof but you can't close them. Both open and close functions work for the models built before 2008.
Post by yani » 03 Dec 2010, 11:08
I think I wrote this somewhere, but anyway, in order to find how to turn on this feature for 147 I need:
- CAN Info report from 147 with this feature working properly
- CAN Info report from 147 without this feature
- people with 147 who wish to test...
The same is valid for 159. I need two reports from vehicle with and without this feature.
leopard
Post by leopard » 04 Dec 2010, 22:37
Hi Yani,
FESLog_1012042007_ALFA 147 1.6 TS 16V 120CV.txt
(1.51 KiB) Downloaded 837 times
