Closing windows with the remote key AR 147
Hi Yani if you are able to "turn on" closing windows with the remote key, because I have two AR 147 and one of them has the opportunity in the second, but you can only open the window using the remote control of a key, so I suppose that, because of the security features turned off but from experience I know that you can turn it like, for example, is VAG group
The function would certainly be very useful in other models of the Fiat group
ThX
ThX
Re: Closing windows with the remote key AR 147
Hello again Yani, I read a bit about the closing of windows in the DTE (Electronic Technical Documentation) and this feature is called "Superclosure" and that the work must be in the door seals anti-crush sensor, and are indeed, such a proposal that the function of closing windows with the remote control is off in BC so it is possible to enable this.
Thanks for replying
Thanks for replying
would be very useful ....
to add?
to add?
I am interesting in purchasing Multiecuscan but the only feature that interests me is enabling the SUPERCLOSURE for Alfa 159.
Is that planned for a future version or is it even possible to be achieved via OBD - I know that the Fiat Examiner can't enable it.
Please, may I have an answer?
I'm not asking when if that feature will be included, I just want to know if that's even possible or not.
Do you know for a fact that your car (Alfa 159) hardware and software supports "superclosure"?
If so then stating which model (Version Code), year and country may help.
Yup. Every 159 has superclosure but for some reason (some people suspect a lawsuit) they disabled the close function for all the models built beginning with 2008. So basically you can open the windows/sunroof but you can't close them. Both open and close functions work for the models built before 2008.
I think I wrote this somewhere, but anyway, in order to find how to turn on this feature for 147 I need:
- CAN Info report from 147 with this feature working properly
- CAN Info report from 147 without this feature
- people with 147 who wish to test...
The same is valid for 159. I need two reports from vehicle with and without this feature.
Hi Yani,
- FESLog_1012042007_ALFA 147 1.6 TS 16V 120CV.txt
- (1.51 KiB) Downloaded 837 times
