Post by yani » 02 Oct 2010, 19:38
dusan147 wrote:It is OK if this behavior is normal, but this is uncomfortable for me.
Do you have some recommendations about hardware solution of this problem (additional power supply line, for example)?
Maybe will be helpful information that problem doesn't appear if I am connected and no items in "Parameters" section are selected...
Unfortunately, I don't have a solution for this ELM problem yet.
I'm just using the VagCom interface when connecting to the engine. It does not disconnect when starting the car.
dusan147
Post by dusan147 » 03 Oct 2010, 04:53
Yes, It is proper solution...
Being Merlin and not Arthur!
stilos
Post by stilos » 08 Oct 2010, 12:37
My ELM had the same problem.
I've removed the unwanted resistor and I1ve installed new ones to correct position.
Now it works properly.
Thanks for Great help.
stilos
Fiat Stilo 1.4 16V and Fiat Bravo T-Jet owner
stilos
Post by stilos » 08 Oct 2010, 12:47
I had the same problem. I removed the wrong resistor and installed new resistors and capacitors in accordance with posted above and wiring sheet.
It was a great help. Now my ELM interface works properly.
Alfa-NSO
Post by Alfa-NSO » 14 Oct 2010, 12:21
sprint750 wrote:Hello,
It was sold as ELM 327 1.4 'with a genuine ELM chip'. :?
Best regards
Sébastien
Hi Guys,
i have the same inerface but i can connect to the ECM only, no SDM and no ABS possible with error message "please use KKL", why?
Regarding the mod. instructions on yanis post.... this interface have the 100ohm resistors on the CAN line, do i still have to to modifiy it?
Alfa-NSO
Post by Alfa-NSO » 14 Oct 2010, 12:29
Best regards
Sébastien
Hi Guys,
i have the same inerface, but i can connect to ECM only, no SDM or ABS possible with error massage "please use KKL", why?
This interface have the 100ohm resistors as mentioned on the first post, do i still have to modfify the connections?
mattydr67
Post by mattydr67 » 17 Oct 2010, 04:55
If it said so "please use kkl interface" you need to use a kkl interface.
The elm327 dosen't support all ECM's
Try to connect to a controler on CAN.
This is what we are talking about here, problems with CAN connections
Alfa-NSO
Post by Alfa-NSO » 17 Oct 2010, 20:24
Hi Matty,
i have no prob. to connect to my ECM...... it works fine.
I can not connect to my SDM and ABS ECU and im sure that they are on CAN (wiring diagrams), they nethier getting found by the ECU search.
My question was if i have to modify my ELM (pin 1-7-9) to connect to SDM and ABS!!
nickromano
Post by nickromano » 21 Oct 2010, 01:18
Hi guys, I have the same interface, same board but it was sold to me as ELM 1.3a, i can connect to the engine but i cant access service reset, instrument panel or any other.. I have a Lancia Ypsilon 1.3 jtd (2003)
Do I have to sold any pins? I checked http://www.multiecuscan.net/SupportedVehiclesList.aspx and shows (ELM) only for what i need (service reset)...
please help
mattydr67
Post by mattydr67 » 23 Oct 2010, 04:43
Alfa-NSO wrote:Hi Matty,
Mate
If your ABS isom CAN you don't need to make any soldering but if ABS is on KKL you need to make it.
Well now if ABS is on CAN abs it and doesn't work you really have a problems with your tool and you can try Yani's way to fix it.
If the sw ask you for VagCom interface for sure your ABS is on K-line and you need to seldering the pin 7 and 1. But here it is a big problemn for you becasue I think you have one of this ABS ecu's which doesn't work with ELM327 interface, just with VagCOM (KKL) interface or with OBDKey:
- Bosch ABS Teves MK20/MK70 (VagCom/OBDKey only)
- Bosch ABS 5.3 (VagCom/OBDKey only)
- Bosch ABS 5.3 TC(VagCom/OBDKey only)
- Bosch ABS 5.3 ASR(VagCom/OBDKey only)
