INTERFACE TYPE REQUIRED FOR EACH MODULE!!!
Post by yani » 06 Sep 2010, 16:05
I updated the supported vehicle list with interface type and modifications required to connect to each module.
Re: INTERFACE TYPE REQUIRED FOR EACH MODULE!!!
Post by s130 » 06 Sep 2010, 17:55
Great Yani
This update is most welcome as we have all seen there is quite a lot of confussion & questions out there.
May I suggest you give a little better qualification to "connection to Pin n"
i.e. I believe you mean "Pin 7 should be connected to Pin n"
mattydr67
Post by mattydr67 » 17 Sep 2010, 08:27
Yes that's right it is about pin 7 (k-line)
LiNuXxX
Post by LiNuXxX » 20 Sep 2010, 07:43
That's a very user freindly update.
This makes it al clearer for editing or not editing your cabble.
Is it mayby possible to link or place a foto/manual for the differend types of cable?
It's not always evident to find a message back in the forum concerning this.
PunTosse
Post by PunTosse » 08 Dec 2010, 13:33
Yes it would be a god help with pictures, and evt. drawings. Cause it can be a pain in the b.. to understand what other mean when you are a noob. :?:
Post by yani » 15 Dec 2010, 10:03
I updated the page with supported vehicles/systems at
I added complete wiring diagrams and explanations for creating adapter cables instead of modifying your interfaces!
Post by s130 » 15 Dec 2010, 10:47
Good job Yani
I've just carefully read all your changes. They are clear and concise and I can't see any errors.
For everybody else I would suggest when we see any more questions about modifications we direct them with a simple
"Please read"" http://multiecuscan.net/SupportedVehiclesList.aspx
I think that if the user wants to modify their actual interfaces then they will have to work out how to do this themselves based on the info in the above link. With so many different interface makes and circuit boards then it is not practical to show interface wiring modifications.
PunTosse
Post by PunTosse » 15 Dec 2010, 19:39
Kudos to you Yani
You have done a very good job, now even I can make a working cable. :D
Pipen
Post by Pipen » 14 Jul 2011, 06:31
what is the best interface to buy and use with FiaEcuScan?
My only interest is live data loging form engine ecu and to work with diesel ecus.
As i soo obdkey is the way to go?
Regards
Post by alfa156sarajevo » 15 Jul 2011, 09:34
Pipen wrote:Hello,
Regards
Go to: http://www.multiecuscan.net/SupportedVehiclesList.aspx
There you can find your car in the list and you will see which interface or interfaces you need (one or two)! ;)
P.S. If you have enough money for OBDKEY just buy it! :)
