Programming the remote in test mode
bas
Post by bas » 20 Jun 2010, 20:52
After entering electrical code:
and it hangs, did not check when connected to the car.
BAS
Re: Programming the remote in test mode
Post by yani » 21 Jun 2010, 06:38
There is something wrong with the language file that you are using.
It is missing keys 6061 - 6073.
Please, use the language files that come with Multiecuscan 2.3, or add those keys in your language file.
bas
Post by bas » 21 Jun 2010, 08:14
yani wrote:Hi,
Uninstalled(and i deleted the whole directory), downloaded a new copy from your site and now I have this problem: viewtopic.php?f=6&t=1094&p=2783#p2783
BAS
Post by yani » 21 Jun 2010, 08:29
bas wrote: Uninstalled(and i deleted the whole directory), downloaded a new copy from your site and now I have this problem: viewtopic.php?f=6&t=1094&p=2783#p2783
BAS
That user has a problem with the free version. You have a license and you should be able to change the language from the Settings window.
bas
Post by bas » 21 Jun 2010, 08:33
BAS
Ok, I'll check, actually I have tested on the FREE version on the virtualbox in the test environment, non-productive.
BAS
Post by yani » 21 Jun 2010, 08:45
Ok, sorry, again, for the inconvenience but I found the problem and fixed it.
You have to download the installer again and reinstall.
bas
Post by bas » 21 Jun 2010, 09:02
yani wrote:Ok, sorry, again, for the inconvenience but I found the problem and fixed it.
Still the same problem.
BAS
Post by yani » 21 Jun 2010, 09:06
Still a problem with the messages when programming remote controls?
Or still a problem with the data language? Please post a screenshot if you have a problem with the data language.
bas
Post by bas » 21 Jun 2010, 09:10
yani wrote:still a problem with the data language?
Yes, checked on a FREE version.
yani wrote: Please post a screenshot if you have a problem with the data language.
BAS
Post by yani » 21 Jun 2010, 09:13
That should not be a problem.
It says "Cesky" but the data in the free version is always in english. This selection does not matter in the free version.
