Alfa Romeo Giulietta fault code P242A description
Gary
Post by Gary » 04 Jan 2022, 11:20
I have been using Multiecusan on a 2010 Alfa Romeo Giulietta - engine module Bosch EDC16C39
The vehicle had a permanent fault triggering fault code P242A.
Multiescan error description for P242A is Turbo inlet temperature sensor
Using a different diagnosis scan tool the same fault code of P242A was seen but with error description of exhaust temp sensor.
Multiescan was showing Turbo inlet temperature of 999degree C within parameters tab. Inline with open circuit wiring.
The actually vehicle fault was an broken wire for the exhaust temp sensor. When wiring was fixed fault code P242A was not shown in later scans.
It would appear that the incorrect error code text for P242A is in the Multiescan database for 2010 Alfa Giulietta.
Could you please check this?
Kolya07111
Post by Kolya07111 » 03 Apr 2023, 16:24
I am using ESP32-WROOM with AT commands. When I send CWJAP command with wrong password, the module responds with error code 4 instead of 2, I whant to know why this is happening.
Could you help me with this?
Re: -
Post by s130 » 04 Apr 2023, 07:13
Kolya07111 wrote:
03 Apr 2023, 16:24
Can you explain wahat or how this post is related MES?
