Gearbox change
abuk8
Gearbox change
Post by abuk8 » 24 Feb 2021, 09:33
Hello, I have a problem with my cruisecontroll. Previous owner swap the gearbox (Grande Punto 1.9 120HP) from the 130HP engine. And because of this i cant use my cruise controll. It would be great to have the possibilities to change gear ratio or gearbox. Thanks.
shpuncik
Re: Gearbox change
Post by shpuncik » 24 Feb 2021, 15:08
this is beyond MES scope. you need to make changes in engine ecu software for right gear ratios. find who specialize in engine tuning - they should be able to sort this out.
abuk8
Re: Gearbox change
Post by abuk8 » 21 Feb 2022, 21:57
shpuncik wrote:
24 Feb 2021, 15:08
I found in 4.8 MES in proxy alignment posibilitty of gearbox cahange there is manual, selspeed, ddct, automatic and then type 5,6..etc. Do you think that this could be solution?
abarthmultijet
Re: Gearbox change
Post by abarthmultijet » 23 Feb 2022, 16:59
I think it could be a solution, first save the proxy code (control-alt-C when in the proxy allignment tab) to windows notepad. Then try the different gearbox type's.
chrener
Re: Gearbox change
Post by chrener » 07 Mar 2022, 19:42
You need to change "final Ratio"
Jo_Neu
Re: Gearbox change
Post by Jo_Neu » 31 Mar 2022, 21:01
Hi, i have the same Problem with Ducato Multijet 180 from 2013.......
How can i change the points of Gearbox??
Thx
Jo_Neu
Re: Gearbox change
Post by Jo_Neu » 01 Apr 2022, 18:10
abuk8 wrote:
21 Feb 2022, 21:57
shpuncik wrote:
24 Feb 2021, 15:08
Hi, do you have tested it?
This will be very interest
abuk8
Re: Gearbox change
Post by abuk8 » 19 Mar 2023, 21:15
Jo_Neu wrote:
01 Apr 2022, 18:10
abuk8 wrote:
21 Feb 2022, 21:57
shpuncik wrote:
24 Feb 2021, 15:08
No i try just free version. I dont want to destroy it
BBOinsam
Post by BBOinsam » 03 Mar 2024, 00:40
Thanks but I kinda dont know how to change that. I was looking through all the skins in bitmap and couldnt find anything. I might have to add my own?
