Yoyyava
Post by Yoyyava » 14 Jan 2022, 21:09
Hello everyone!
Firstly thanks for your help because time ago I was able to modify an old cable elm327 with your help and advices. :D
I am trying to have another one but I have received an strange circuit board which I have not found over here. Does anyone know it and can help me with it?
Your help would be very appreciated :mrgreen:
Thanks in advance for your time, help and knowledge.
Dunk_c
Post by Dunk_c » 14 Feb 2022, 17:15
Alex2610 wrote:
04 Jul 2021, 06:22
Hello, i constatly receive the "can bus" error in multiecuscan, the test gives all ok back.
Scanmaster dectects the ECU, multiecuscan does not.
Photos
I just bought a similar interface (at least the main side of the board). Installed the CH304 driver on my old XP laptop.
MES connects to the car using this interface but does not show any live parameter values. Did you get yours going?
fantictt4@gmail.com
Post by fantictt4@gmail.com » 07 Apr 2022, 18:51
Salve chiedo a voi esperti perché non riesco neanche a superare la fase di test con multiecuscan e via alkego le foto interne dell'interfaccia acquistata su AliExpress r dopo varie ricerche non trovo nulla di simile,dimenticavo devo connetermi sul bodycomputer per fare la modifica del serbatoio carburante da 60 a 90 lt. su fiat ducato x290 del 2019
Mxman23
Post by Mxman23 » 15 Nov 2022, 18:48
https://ibb.co/c8R9rMW
https://ibb.co/PmfNrHW
Need help with what resistor to remove thanks in advance
Ppao
Post by Ppao » 04 Dec 2022, 09:46
i have problems with connection to a fiat 500x 1.4 T-JET/MULTIAIR. I have a elm327 module 3.0 since about 10 years and never problem with the old cars.
But today i can connect to this fiat in order to clear maintenance indicator. When i connect to service/service interval reset (334), i have a execution error message. I can connect to the engine without problem
my multiecuscan version in 4.9 registered.
May be i should have a multiplexed version ?
Post by s130 » 04 Dec 2022, 18:17
Have you used the correct adapter cable? No:3 / Yellow
Fubuki28
Post by Fubuki28 » 06 Dec 2022, 02:23
Hi, I am asking for help with my odb2. It only connects to the ecu for 5 seconds then crashes and disconnects in every program and application. This is obd2 "ymiot b18-3 wifi". And the car is a Fiat Bravo 2.
https://imgur.com/a/RgaGje8
https://imgur.com/a/zWh9gjg
https://imgur.com/a/DRgmTom
Ppao
Post by Ppao » 06 Dec 2022, 21:17
s130 wrote:
04 Dec 2022, 18:17
Thank for your answer
I think so. i try to connect the yellow cable but it does not work.
roby89br
Post by roby89br » 20 Dec 2022, 17:31
Hi, i have this eml 327 BT interface, I also bought a yellow cable for my Giulietta.
What I have to modify?
Thz
I wasn't able to upload photos.
https://mega.nz/file/sEEATJbT#ZZg2x1cU5D_xTHnNmwwPtSKqepDzLa9ReC9tbtnU8eI
ishipuri
Post by ishipuri » 10 Jan 2023, 14:03
First, about machine translation
there may be a problem with the translation
very sorry
good evening everyone or hello
My favorite car is Alpha Mito 1.4 Turbo
Can't connect due to interface problem, image error
I would appreciate it if someone could help me
the interface is an image
I tried to take it apart but I don't understand
This interface also
Is it possible to connect by replacing resistors, capacitors, etc.?
