Hi all,
i will align the proxy on my 500x 1.4 140cv after uconnect swap (6.5 to7)
how to enable thev rear camera?
thank you 4 your help
rear camera after uconnect swap
Re: rear camera after uconnect swap
Check in engineering menu in RVC status if your U7 have RVC support...
thx look on this picture, in Engineering mode RVC config is in grey not in white
I can't go to the RVC config
Only basic Data (FW number)
https://1drv.ms/u/s!AhaD6GepAxliljvsCHN6GoGHNAIj?e=xPagop
it's ok
my fiat 500X with uconnect 6.5
I brougth an uconnect 7 (version 500X 2020) with double USB (it's important) on Ebay.
When i mounted it on my 500X (2016)
Milage flash and rear camera have disappeared
With multiecuscan + blue and grey plug, i realign the proxy with a custom.......
My new Uconnect 7 works fine with activation of carplay.
anchio sono passato da uconnect 6.5 al 7 e solo la telecamera non compatibile con il 7 va cambiata
[S130 moderator]
I also switched from uconnect 6.5 to 7 and only the camera not compatible with the 7 should be changed
[S130 moderator]
