Alfa Romeo Giulia Continental ABS MK C1
General messages
Italia-Tec
Post by Italia-Tec » 03 Oct 2020, 18:44
Hi Forum,
Recently I tried to connect to the Continental ABS MK C1 of a Alfa Romeo Giulia 2.0 Veloce 2017 with my multiplexed version 4.6R1 and got the message to use adapter 6 (Gray) which I don't have. Does this sound correct as I thought the adapters were for non multiplexed versions, I don't mind purchasing said adapter if that's what is required.
Just to add I didn't have any issues connecting to the engine control module!
Could anyone help or advise on this please.
Kind regards,
Matt.
Re: Alfa Romeo Giulia Continental ABS MK C1
Post by s130 » 04 Oct 2020, 08:53
Someone else has reported a similar adapter requirement.
The Gray adapter is the latest new requirement for some vehicles. This means (I think) that earlier versions of Cantiecar/Multiplexed interfaces do not currently support the later pin switching required.
Before purchasing a cable I would get in contact with your interface manufacturer to see if there is a firmware update available.
http://tiecar.net/
Italia-Tec
Post by Italia-Tec » 04 Oct 2020, 14:17
Thank you.
bowdenandymecom
Post by bowdenandymecom » 15 Oct 2020, 14:40
My Multiplex MES connects to the ABS unit of my Giulia Quadrifoglio OK. It's a February 2017 car.
I do however have ABS errors displayed on the instrument panel when I connect MES to the ABS.
Andy
Post by s130 » 15 Oct 2020, 16:48
When MES conntect to some systems like Airbar or ABS then the dash will display the various error lights. This is normal.
What is important is:
1) All the lights go out after disconneting MES and cycling the ignition
2) No errors logged
bowdenandymecom
Post by bowdenandymecom » 15 Oct 2020, 18:07
Certainly, no warnings remain after MES is disconnected and no errors are logged.
