SGW Module Detected
ricocerda01
SGW Module Detected
Post by ricocerda01 » 22 Apr 2020, 16:29
I have the newest SGW Bypass installed from Alfissimo. When connecting to the BODY - CAN SETUP/PROXY ALIGNMENT, I get the following ERROR:
WARNING SGW MODULE DETECTED
I am using Multiecuscan 4.6R1
https://drive.google.com/file/d/1j94MvPeia3o-zCKLyt0dPn2jgYYHTOKP/view?usp=sharing
Any suggestions?
Re: SGW Module Detected
Post by s130 » 23 Apr 2020, 07:30
I think MES says that it is detecting the missing SGW because MES is looking at proxi or other data to make this determination.
Suggest you try a simple actuator test (eg connect to the body computer and turn a light off and on, or connect to the engine ECU and test the engine fan). If the test works then the SGW is obviously not there (yes I know you removed it) but at least you will have a better understanding.
ricocerda01
Post by ricocerda01 » 23 Apr 2020, 14:08
I tried to test the fan: FAILED TO EXECUTE.
shpuncik
Post by shpuncik » 23 Apr 2020, 14:18
all I can see is warning, it's not error. find module with errors inside and try to delete them - in case of success sgw bypass module works fine. otherwise something wrong with it.
ricocerda01
Post by ricocerda01 » 23 Apr 2020, 15:15
SCAN RESULTS
Scanning ...
Engine / ECM
Magneti Marelli IAW 10JA CF6/EOBD Injection (2.0)
ISO Code: 00 01 50 5C 17
ZF 8HP50/75 Automatic Gearbox
ISO Code: 00 0B 50 AA 14
Gearbox / ESM/GSM/NSC (Gearbox Selector Module)
ZF Electronic Gear Shift Module
ISO Code: 00 16 50 B4 14
Body Computer Marelli (952)
ISO Code: 00 00 50 5D 14
Body / RFHUB (Radio Frequency Hub Module)
UNKNOWN/UNSUPPORTED
ISO Code: 00 41 50 BE 14
Errors found:
B1040-64
Dashboard / IPC (Instrument Panel Cluster)
Instrument Panel Continental
ISO Code: 00 03 50 8B 14
COMPLETED
I cleared the errors and went through the steps to enable race mode, but it is not indicated anywhere. NO ABS off on dash etc. and teh DNA knob does not highlight for RACE
shpuncik
Post by shpuncik » 23 Apr 2020, 15:24
Are you turning DNA knob far enought? When you meet first resistance you need to turn even further.
ricocerda01
Post by ricocerda01 » 23 Apr 2020, 15:50
That was it! LOL
Thanks!
But the Waring for SGW was Bull Shizz and did let me write to all needed modules.
shpuncik
Post by shpuncik » 23 Apr 2020, 16:05
ricocerda01 wrote:
23 Apr 2020, 15:50
That was it! LOL
Thanks!
You're not the first one DNA knob has fooled ;)
SGW warning is due to it's presence in proxi config. That's however has no impact performing changes or adjustments.
ricocerda01
Post by ricocerda01 » 23 Apr 2020, 17:26
I went with Type 3/DNA/Sport but I only show ESC OFF and SPEED CONTROL OFF as being disabled on my dash while in Race MODE.
I have a 2018 TI Sport
Is that normal for TYPE 3 DNA?
Heres the pics: https://drive.google.com/open?id=1XmsursY9BbA0V5QYzwZ-Z0Qbmhe3IWP2
https://drive.google.com/open?id=1HWUrgdnjnXSl-IQjPIesikwVJFSEwHP6
shpuncik
Post by shpuncik » 24 Apr 2020, 08:54
ricocerda01 wrote:
23 Apr 2020, 17:26
you don't have lane guidance and front collision warning so you will see ESC and cruise off indicators.
you can also try type 2. don't remember exact differences between type 2/3.
