US 2012 Abarth with 2015 TFT
General messages
NYC Eng
Post by NYC Eng » 08 Jan 2019, 16:26
Is there a setting in the TFT cluster module for hill start assist?
I installed a 2015 TFT cluster in my 2012 but lost hill start assist.
It's turned on in the menu of the cluster.
I updated byte 65 to 60 (which looks much better), engaged the hazard illumination on deceleration, and also disengaged the seat belt chime.
Is there is a way to quiet down the chimes? The turn signal noise is a lot louder in the TFT cluster.
Any chance Yani can get access to shutoff the horn beep when you lock the doors so we only have lights flash? I'll gladly pay for that feature.
Aktif8
Re: US 2012 Abarth with 2015 TFT
Post by Aktif8 » 03 Apr 2019, 15:55
There's an alternate way of disabling the horn - if you disconnect the stock horn and install an air horn, the brief pulse upon lock isn't enough to actually sound the horn, and it locks silently.
MRCOOLDUDE
Post by MRCOOLDUDE » 10 Oct 2023, 22:37
Hi. I am interested in learning how to turn off the seat belt chime. How is this accomplished?
shpuncik
Post by shpuncik » 11 Oct 2023, 09:01
MRCOOLDUDE wrote:
10 Oct 2023, 22:37
check in instrument cluster, usually there is option to disable it.
MRCOOLDUDE
Post by MRCOOLDUDE » 11 Oct 2023, 14:52
I have looked, several times. There is not. I think this option is perhaps available on newer or older models of the car. I have the 2013 version. I was hoping there was some way to do this with MES and I have been informed that there is.
abarthmultijet
Post by abarthmultijet » 12 Oct 2023, 21:05
MRCOOLDUDE wrote:
11 Oct 2023, 14:52
Go to dashboard -> instrument panel (which is the right one for you) -> adjustments -> deactivate seatbelt allarm
