Fiat Panda 4x4 - 2014
General messages
Sophie IT
Post by Sophie IT » 02 May 2018, 15:52
hello, i have the fiat Panda new model (2014)
The motor is twinair 0,9 turbo
I want to by Multiecuscan for reset maintenance notice
what version of the software do I need?
and what cables and interfaces do I need?
i'm confused.. :?
where can I buy?
thanks for any help
Sophie IT
Re: Fiat Panda 4x4 - 2014
Post by Sophie IT » 03 May 2018, 12:00
can anyone help me?
following the table for the Fiat Panda twinair 0,9 -2012
I understand that I need:
-ELM 327 v1.3+/OBDLink/OBDKey interface without adapter (unmodified)
-adattatore: A3 - ADAPTER CABLE 3 (yellow)
it's correct?
but I ask: where can I buy these original pieces? (I'm not interested non-original pieces)
thanks for the help
Sophie
Post by s130 » 03 May 2018, 17:32
Please refer to this page http://www.multiecuscan.net/Distributors.aspx
Find a distributer in your country.
These official distributers only supply kit that works and will give good support.
Going elsewhere may be cheaper but may also be troublesome.
davidino66
Post by davidino66 » 04 May 2018, 11:30
Sophie IT
Post by Sophie IT » 04 May 2018, 13:03
thanks s130 and davidino for suggestions
ps:davidino you have a private messagge ;-)
Sophie IT
Post by Sophie IT » 03 Jun 2018, 13:29
I tried the version 4.1 free and I saw that it connects to my panda ;)
Now I want purchase registered version
I have two questions:
1) I can buy too multiecuscan.net (this site) or to have italian language I have to buy for italian rivenditor?
2) on my laptop, I often re-install the operating system (every 6 months) to have high-performance computers
(nb: I mean without changing hardware)
Every re-install system operation, Is it a problem for the license?
thanks
Sophie
Post by s130 » 04 Jun 2018, 10:24
You can buy MES here on this website. MES allows you to change the language in the *licensed* version.
Regarding re-installing your operating system or changing hardware the please read the instructions in the MES User Manual. See http://www.multiecuscan.net/HowToUse.aspx and click the "Download Manual" link. See Section 3 - "MultiECUScan License", Pages 10, 11 and 12.
Sophie IT
Post by Sophie IT » 05 Jun 2018, 02:29
thanks ;-)
I have read user manual pag.10-11-12, but it is not clear
I do not change computer (or hardware..) when I re-install system operation
I re-install on the same Pc...then ID Hardware is always same
The manual saY:
[Please note that the License Transfer function has a limitation on the number of
transfers.]
but if I do not change Pc / hardware, is not correct that I have limitations for install Mes
ON THE SAME PC/HARDWARE!
thanks
Post by s130 » 05 Jun 2018, 10:43
It is my understanding that if you are just re-installing the *same* OS version (eg Win 7) on the same hardware then you do not have to do a license transfer as the hardware key I believe is the same.
I only pointed you at those pages so you understand how the activation works. You should still make a note of all keys just in case. If you run into problems then MES Support will require the information from you (purchase info, key, etc.) to validate you as a licensed user and not somebody trying to obtain a free activation.
Sophie IT
Post by Sophie IT » 05 Jun 2018, 23:07
thanks, ok I get it
I will convince my father to buy the license
