semaphore timeout on bravo 13 elm 1.3 r1 no 120 res
righi
Postby righi » 09 Mar 2018, 06:03
greetings!
I've been gathering some info from this awesome website for the past days and now I have my own usb elm 327 1.3 R1 version and tried connecting it to my 13 bravo tjet to no avail
error message is THE SEMAPHORE TIMEOUT PERIOD HAS EXPIRED or something like that, whenever I try to use it. The software I have is FiatECUScan 3,6,2 and I need to perform a PROXY ALIGNMENT after replacing the awful medianav, rendering me a flashing odometer
must I get the so-called yellow adapter, seeing that I live in Brazil, importing one would take months, if really necessary, can I just rearrange the wires somehow?
I went ahead and removed the 120Ohm resistor mentioned in the other topic
any pointers are greatly appreciated ;)
Re: semaphore timeout on bravo 13 elm 1.3 r1 no 120 res
Postby s130 » 09 Mar 2018, 10:12
A few points to note:
To my knowledge the last version of FiatECUScan was V3.6 (on 26 May 2012) and not V3.6.2.
Where did you get the software from?
FiatECUScan is no longer supported and went out of service on 26 May 2013 .
May I suggest you download the current free version of MultiECUScan V4.0 and try to connect to your car.
Start MES, select you vehicle and then do a SCAN (PF11). This will check the basic connection link to your car and list the vehicle's modules/nodes.
Now look here: http://www.multiecuscan.net/SupportedVehiclesList.aspx to see which items listed in BLACK text (and not RED) for the specific modules you will be able to connect to with this free version.
If you are happy then go and purchase a license so you can do the Proxi Alignment you require.
righi
Postby righi » 09 Mar 2018, 13:57
hey! thanks for the heads up
I did that, but still nothing
at least the error changed, apparently
its weird it says 1.3 r1 on the board but it shows 1.5 on the software, the driver it installed was USB-SERIAL CH340, and port assigned (com) correctly
any ideas? thanks again!
Return to “Usage Q&A”
Who is online
Users browsing this forum: No registered users and 5 guests
