![Image](http://s32.postimg.org/5a7rundfp/img0.png)
![Image](http://s32.postimg.org/6ijakpsjp/img4.png)
![Image](http://s32.postimg.org/gqis6fgzp/img1.png)
![Image](http://s32.postimg.org/4am2connp/img2.png)
![Image](http://s32.postimg.org/otgyhr1l1/img3.png)
OK.
Theese are the screenshots of my test with EasyOBD, ScanMaster and MES !
badcat wrote:Hello,
I have this interface elm327 wifi:
https://drive.google.com/open?id=0B7_IY ... DJDN3lLcXM
I do not understand what resistance I have to remove.
emekilker wrote:hi friends,
my car 2008 Grande Punto 1.3 MultiJet. i want cruise control enabled.
my elm 327 this:
i did this modification:
i use this drivers:
but i can't connect to body. i can't enabled to cruise control
How i can this?
Thank you for your answerAlfaeddy wrote:Hello
Is your ELM 327 Bluetooth Interface?
and MES, the free version?
And further :
If the result is displayed in the interface test of MES.
Can the interface does not work with MES and is not compatible
Then it is useful not to remove the bridge resistor also
Uh. Ok thank you. I will try with registered version somehow.Alfaeddy wrote:Hello
I have heard of another user that the free version of MES no Bluetooth connection can be established.
This is only possible with the registered version?!?!
But if your interface does not pass the test
it does not work with MES
and you have to buy another interface.
Also I can here not set more pictures !!
And also get no info why ??
