I need a good advice/help...
I got my Doblo since 2010, little faults etc, all sorted by myself and my ELM+Multiecuscan (this is why we are here
![Wink ;)](./images/smilies/icon_e_wink.gif)
...but now I stuck.
Little prelude: Doblo 1.9JTD type 223, 1.5yrs ago bought from ebay a tuning box, (from TDI-Tuning), perfect, in city the fuel consumption dropped from 9l to 6.7l/100km... 1 months ago I removed all the injectors, got new seals, sorted.
Prepared the car for a long England to Hungary trip, same as we did last year without any problem... ~2100km in 5.7l/100km average perfect.
But, backway, just in the middle of Germany limp mode,
![Shocked :shock:](./images/smilies/icon_eek.gif)
I guess, its tried to start a DPF cleaning, but as it never was success ( I did it manually before) and this is why it went to limp mode...
But why I cant see the ECU (I got a U1601 C-Can line error), before I was able to connect
-F16 7.5amp fuse checked, OK
-ECU connectors contact cleaned
And now, my Doblo not rewing upper than ~3200, black smoke, no power.
Today morning I checked all the connections in the engine bay fusebox, the other box (in the middle, just over the engine), and the driver side fusebox front, I left few more connections on the back, but I didnt had time to clean that side. Cleaned (with carb cleaner) and reconnected the MAF sensor.
Didnt started the engine as I halfway in the EGR cleaning, just tried to connect to the ECU, and still the same.
Only the Body computer and the Dashboard appear, the engine not.
The funny thing is, nothing changed, same laptop, same ELM adaptor, same 1.7 registered multiecuscan, the above two comp. is working and communicating, so the rest should be fine...
So this is the sad situation...
Any answer and solution appreciated.
Thanks in advance!
