Multiecuscan 2.0 - WORK IN PROGRESS!!!
General messages
EnIgMa
Re: Multiecuscan 2.0 - WORK IN PROGRESS!!!
Post by EnIgMa » 31 Mar 2010, 21:35
yani wrote:Please be patient! I'm working very hard to release v2.0.
As far as I know Fiat Grande Punto (2007) is CAN-only. You cannot do anything with VagCom cable. You'll need ELM 327.
However, it will not be supported in v2.0. I'll add support for Grande Punto soon.
Great! Great!
Just, i didn't understand if we will have to modify the cable of elm-device as we do for the vagcom cable or not.
thank you! :)
sixpotman
Post by sixpotman » 31 Mar 2010, 22:43
More than likely if the pins are not connected
I have a Gendan Elm and it will need altering
to work.
John
Post by s130 » 01 Apr 2010, 17:38
Gendan Elm Interface
Care to clarify? Why would this interface require modification?
sixpotman
Post by sixpotman » 02 Apr 2010, 18:08
Gendan Interface needs altering as not all the required
pins in the diagnostic socket are connected for diagnostics.
Same as the VAG.
John
brutale
Post by brutale » 03 Apr 2010, 07:07
need translate to Chinese?
I can help
Regards
kayman
Post by kayman » 12 Apr 2010, 12:42
Tried to connect via ELM 1.5a, but it didn't work. So I have ordered an ELM 1.3 and hope, that it will work to reset the Service message at my Stilo 1.6...
Kay
Flo13
Re: Multiecuscan 2.0 - support ABS Teves Mk20
Post by Flo13 » 14 Apr 2010, 00:22
mike1327 wrote:Hi Yani! Will version 2.0 support ABS Teves Mk20 for Fiat bravo 1.9JTD, 1999
Your vehicule was made after 1998 so it's not anymore a TEVES MK 20 ABS, but a BOSCH 5.3 ABS.
I give you a tip to easily reconise your abs type :
- TEVES MK 20 : On the front wheels, the sensor rings are positioned on the transmission drive shaft
- BOSCH ABS 5.3 : On the front wheels, the sensor rings are in the bearing seal
