VAG KKL cable connections
Re: VAG KKL cable connections
Post by Alfaeddy » 17 Dec 2013, 11:49
Hello Monax
Whoud you buy a ELM
This ELM have not an Bridge Resistor
The Seller has remove the Bridge Resistor
of my Infomation
ELM Interface usb
http://www.ebay.de/itm/160996649487?_tr ... EBIDX%3AIT
And a Adapter A3
http://www.ebay.de/itm/151015670657?_tr ... EBIDX%3AIT
Send him a greeting from me :D ( Eddy)
Greetngs Eddy
Gatter
Post by Gatter » 19 Dec 2013, 15:42
Hahaha Check this out! My new chineese VAGKKL cable..
Airbag is soldered to pin4-5, instead of pin3! :D
ESP is soldered to pin11-12, instead of pin12-13. :D
After the modification it works properly.. So first of all you should check the cable for correct pinout. 8-)
Post by alfa156sarajevo » 31 Dec 2013, 18:16
Monax wrote:Eddy Thanks for answer. My order is failed. Minus 16$ for me(( Now i know that i need only ELM
On some Grande Punto models you can connect with KKL to service as I can remember but MES disconnects after some seconds...
Post by alfa156sarajevo » 31 Dec 2013, 18:40
Gatter wrote:Hahaha Check this out! My new chineese VAGKKL cable..
Here is pinout for MES:
pin 1 - ABS
pin 3 - Airbag
pin 7 - Engine/Gearbox
pin 9 - EPS
pin 12 - XENON
On all OBD2 interfaces no matter for which group are they made (Vw, Audi, Ford...) pins 4 and 5 are always connected (soldered) together and on pin 16 is always plus (+) from battery.
Gatter
Post by Gatter » 02 Jan 2014, 15:57
Yes you're right, XENON is on the 12 pin.
But my main problem was the Airbag line. Which was soldered to pin 4-5, instead of pin 3! (Red cable)
D3LTA_NL
Post by D3LTA_NL » 24 Feb 2014, 14:18
I have same cable :)
Can you send me picture of youre modifications?
hungtan
Post by hungtan » 27 Feb 2014, 02:33
I have too. Can you say me, How do I connect my car. Skoda octavia 2.0tdi 103 kw 2004.
Post by Alfaeddy » 02 Mar 2014, 10:37
Hello hungtah
What software do you want to read your Scoda?
Because Multiecuscan can not connect to your vehicle.
That which is described here has nothing to do with your connection problem.
hungtan
Post by hungtan » 02 Mar 2014, 13:43
Hello Alfaeddy!!
I tried with VAG-409 and VCDS-Lite-1.2 .v.v. All inactive.
Post by Alfaeddy » 02 Mar 2014, 18:52
Hello hungtan
As I've written
This is about Multiecuscan and not on VCDS
Why can not connect to the Skoda I do not know.
Greetings Edd
