westfielder
Post by westfielder » 24 Sep 2012, 09:25
Just registered so I can say THANK YOU to all who have contributed to this thread. I removed R04 and can now communicate with all my elm compatible CAN modules.
diablotic
Post by diablotic » 27 Sep 2012, 10:43
I can see many different mobos but I cannot find similar to mine. Can anyone please help me and show which resistor should I remove please?
Post by Alfaeddy » 27 Sep 2012, 11:42
Hello Diablotic
The error you have with your interface?
Which version is your interface?
With which you can control establish a connection?
This ELM interface does not have this annoying resistor
And should really be able to connect.
diablotic
Post by diablotic » 27 Sep 2012, 11:48
Basically when I do the interface search I can find my ELM but I have "latency too high" message at the bottom. All the tests are OK but I can see this error and I also have difficuties to connect to FIAT cars so that's why I thought I need to do some kind of trick with my interface.
Krg
Post by Krg » 27 Sep 2012, 13:52
diablotic wrote:... which resistor should I remove please?
I have the same interface that conforms to the circuit Datasheet (http://elmelectronics.com/DSheets/ELM327DS.pdf)
http://multiecuscan-france.forumgratuit ... elm327-v15
No connection problem.
lolo85v
Post by lolo85v » 27 Sep 2012, 18:13
Hello on my elm I is to remove the resistance r4 but always the problem to reach has airbag
mattydr67
Post by mattydr67 » 27 Sep 2012, 18:54
Do you have Airbag on CAN BUS or k-line?
Or you need to use the 3rd Adaptor for this?
Did you checked the Coverage list to see what you need to acces to your airbag?
By the way did you tried to connect to the BSI or other CAN BUS controlers?
Think about this first then we will see what can be your issue
Post by Alfaeddy » 27 Sep 2012, 19:41
How Mattydr67 already writing
I will once again make clear
The problem with the resistor in the ELM interface affects only
The controllers will be read with CAN (ISO 15765)
And no controls with the KWP2000 (ISO14230) or K-Line (KW1281)
Therefore, not just remove a resistor from the board, often it is also because incorrect settings why no connection can be made.
Also concerns this resistor only this software (Multiecuscan) all other software have no problem with this resistance in the ELM
lolo85v
Post by lolo85v » 28 Sep 2012, 01:10
Hello in fact I have to buy 3 elm I have to remove the resistance on 3 elm 2 on 3 walk(work) tres indeed on airbag 3 eme elm do not arrive.
Post by Alfaeddy » 28 Sep 2012, 07:10
What kind of vehicle?
Model?
Airbag?
