7'' Uconnect retrofit on FIAT 500X - 2015 - 1.4T 170hp 4x4 9ZF
General messages
feelozof
Post by feelozof » 05 Nov 2023, 09:57
I have replaced my 5'' Uconnect with 7'' (Continental FIAT 334 7in VP2 EMEA GPS), it works so far but below issues occured after replacement.
1) KM flashing
2) Rearcam disappeared.
3) On Uconnect safety menus, i couldn't see and set front collusion warning like in the 5'' Uconnects menu (but sensor works, it warns and does emergency break)
I tried to extent proxi and changed some bytes mentioned in forums topics but it failed and engine and 9 speed ZF automatic transmission errors occured, then i return to orjinal (below) proxi from backup.
33 38 33 33 34 30 36 35 34 39 35 4F 55 54 50 55 54 2D 53 49 54 20 15 06 05 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 D1 EA 0F 01 AD 81 07 E2 40 27 A9 07 40 10 10 03 A3 1E 44 92 01 35 73 14 01 4F 03 34 19 B3 AC 01 4A 43 07 00 8A 82 10 EE 00 00 20 04 00 01 03 54 91 C6 06 A5 00 52 00 01 8A 12 3D 40 00 01 03 C5 00 D1 48 10 08 00 49 02 81 12 7B 52 84 00 00 33 AA 99 71 20 80 00 85 00
Would you please help me to activate Uconnect 7'' and correct to above mentioned issues.
Thanks and Regards
feelozof
Re: 7'' Uconnect retrofit on FIAT 500X - 2015 - 1.4T 170hp 4x4 9ZF
Post by feelozof » 09 Nov 2023, 14:08
I manage to solve issues thanks to other topic by Mosby.
Here is my costum proxi, if anyone with 2015 - 1.4T 170hp 4x4 ZF9 FIAT 500X Cross Plus needed.
This one with out DRL menu active;
33 38 33 33 34 30 36 35 34 39 35 4F 55 54 50 55 54 2D 53 49 54 20 15 06 05 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 D1 EA 0F 01 AD 81 07 E2 40 27 A9 07 40 10 10 03 A3 1E 44 92 01 35 73 14 01 4F 03 34 19 B3 AC 01 4A 43 07 00 8A 82 10 EE 00 00 20 04 00 01 03 54 FA C6 06 A5 00 52 00 01 8A 12 3D 40 00 01 03 C5 00 D1 48 10 08 00 49 02 81 12 7B 52 84 00 00 33 AA 99 71 20 80 00 85 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 03 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
After activating ''DRL Menu'' and ''Uconnect 7 Active'' via AlfaOBD, it became as below;
33 38 33 33 34 30 32 31 39 32 32 4F 55 54 50 55 54 2D 53 49 54 20 15 06 05 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 4F 0C 60 45 10 00 19 02 0A 00 00 00 00 00 00 00 D1 EA 0F 01 AD 81 07 E2 40 27 A9 07 40 10 10 03 A3 1E 44 92 01 35 73 14 01 4F 03 34 19 B3 AC 01 4A 43 07 00 8A 82 10 EE 00 00 20 04 00 01 03 54 FA C6 06 B5 00 52 00 01 8A 12 3D 40 00 01 03 C5 00 D1 48 10 08 00 49 02 81 12 7B 52 84 00 00 33 AA 99 71 20 80 00 85 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 03 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
I couldn't have a chance to try carplay / AA because my car has only old type of AUX+USB from 5'' Uconnect.
Thanks and Regards..
Mosby
Post by Mosby » 09 Nov 2023, 16:55
Hi, wow, glad that it was useful for you.
Please tell me what you meant by "Uconnect 7 Active" in AlfaOBD? Is there any such option somewhere?
And by the way, you can try AA even with an old USB hub. It doesn't need a new one.
feelozof
Post by feelozof » 09 Nov 2023, 19:23
Hi again,
AlfaOBD has this section, after connecting to Body Computer go to Active Diagnostic then choose ''Car Configuration'' from list, then, inside, at the bottom of the list you will see ''Uconnect 7 Active''. I dont know what it is changing exactly, but before proxi extention, it doesn't allow me to enable it, but after extent the proxi to 250, it allowed.
Also ''DRL menu'' enabling is under ''Car Configuration'' list.
I know AA can be but right now i don't have an Android Device.
shpuncik
Post by shpuncik » 09 Nov 2023, 19:55
"Uconnect 7 Active" has nothing to do with your radio. it's not used in your car.
feelozof
Post by feelozof » 10 Nov 2023, 06:23
Yes, I couldn't see any difference either, the device worked with the previously extended proxy as well, I made both settings in a completely experimental way and aligned the proxy again and the vehicle accepted it. The 7th, 8th, 9th, 10th, 11th bytes, the 109th byte and the 235th byte seem to have changed, only according to the proxi previously extended.
feelozof
Post by feelozof » 10 Nov 2023, 10:27
Hi again Mosby,
I tried AA with my friends phone, it works like a charm even with an old firmware, mine has SW V. 23.00.81.00 (HW V. D2).
While trying Apple CarPlay nothing happen because of old USB but also no flickering happen during charging like in your case. It just charge as usual...
Mosby wrote:
09 Nov 2023, 16:55
DiReCtX
Post by DiReCtX » 27 Nov 2023, 08:15
Hi I have the same car @feelozof
I added 00 to reach 250 byte change byte 157-01 for AA, modify byte 160-FA but when do proxy only one node (NBS) have timeout
I also tray with length byte 235, byte 106-EB but AT9 has FAILED
Can I ask for help with this PROXI
Regards
CUSTOM PROXI NEW DATA:
33 38 33 33 34 30 35 35 30 36 31 4F 55 54 50 55 54 2D 53 49 54 20 15 06 09 4F 0C 60 45 10 40 00 00 0A 00 00 00 00 00 00 0 0 4F 0C 60 45 10 40 00 00 0A 00 00 00 00 00 00 00 D1 EA 4F 02 AC 82 07 E2 60 27 89 07 40 10 10 03 A3 28 64 92 01 35 73 14 01 4F 03 34 00 B3 A8 01 48 43 07 00 AA 82 10 EE 00 00 20 04 00 01 13 54 FA 9D 06 AD 00 54 20 01 8F 15 3D 40 00 01 03 D5 00 D5 28 10 08 00 49 02 81 12 7B 42 80 00 01 9B AA 97 41 20 80 00 85 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 0 0 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 0 0 00 00 00 00 00 00 00 00 00
ACTIVATING REGULATION...
PROXI 'ALIGNMENT' PROCEDURE
Saving to the module: Body computer (BCM/NBC) SUCCESSFUL!
Writing to the module: Engine Control Node (ECM/NCM) SUCCESSFUL!
Writing to the module: Dashboard (IPC/NQS) SUCCESSFUL!
Writing to the module: Automatic node. gearbox (TCM/NCA/NCR) SUCCESSFUL!
Writing to the module: Gear lever node (ESM/GSM/NSC) SUCCESSFUL!
Registration to the module: Radio Frequency Hub Node (RFHM) SUCCESSFUL!
Writing to the module: Drive Train Control Node (DTCM) SUCCESSFUL!
Recording to the module: Air conditioning node (HVAC/NCL) SUCCESSFUL!
Recording to the module: Entertainment and telematics node (ETM) SUCCESSFUL!
Writing to the module: Amplifier Node (AMP) SUCCESSFUL!
Recording to the module: Electrical support node (EPS/NGE) SUCCESSFUL!
Writing to the module: Braking system node (ABS/BSM/NFR) SUCCESSFUL!
Writing to the module: Steering lock node (NBS) FAILED! - Timeout exceeded
Writing to the module: Parking sensor node (PAM/NSP) SUCCESSFUL!
Recording to the module: Airbag node (NAB/ORC) SUCCESSFUL!
Recording to the module: Road lane control node (HALF) SUCCESSFUL!
EXECUTION FAILED
feelozof
Post by feelozof » 28 Nov 2023, 18:42
DiReCtX wrote:
27 Nov 2023, 08:15
Regards
EXECUTION FAILED
If it is same car with mine, without touching any bytes (except byte 106) of your original proxi, just extend it to 250 bytes and modify same like mine..
FYI .. I used MES 4.7 with blue and grey adapters during the procedure.
Before procedure delete any errors on body computer, disconnect ELM, close car, then connect adapter, switch the key to MAR position and connect to body computer then do proxi alingment again.
I just checked yours and modified as below.
33 38 33 33 34 30 35 35 30 36 31 4F 55 54 50 55 54 2D 53 49 54 20 15 06 09 4F 0C 60 45 10 40 00 00 0A 00 00 00 00 00 00 00 4F 0C 60 45 10 40 00 00 0A 00 00 00 00 00 00 00 D1 EA 4F 02 AC 82 07 E2 60 27 89 07 40 10 10 03 A3 28 64 92 01 35 73 14 01 4F 03 34 00 B3 A8 01 48 43 07 00 AA 82 10 EE 00 00 20 04 00 01 13 54 FA 9D 06 AD 00 54 20 01 8F 15 3D 40 00 01 03 D5 00 D5 28 10 08 00 49 02 81 12 7B 42 80 00 01 9B AA 97 41 20 80 00 85 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 03 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
DiReCtX
Post by DiReCtX » 11 Mar 2024, 20:57
Thank you, proxy works with ZF AT gearbox :D
