Hi there!
I just joined this awesome forum looking for some info. I couldn't find any topic related to my doubt, so here it comes my question.
Newest Abarth 595 come with a hub with 2 USBs to connect to the radio. Mine, as all the older ones, has a hub with Aux+USB.
I would like to upgrade to 2 USBs hub, mainly because I never use Aux port. New hub is required, that is for sure... and I assume that any change has to be done in the Proxy config.
I don't have yet the 2 USBs ports hub yet, I would like to make sure first I can get it installed and working, so I tried first via MES.. I've tried changing it in MES from Type 2 (Aux+USB) to Type 4 (2 USBs) but it doesn't work at all, it puts back to Type 2 automatically. I don't have yet the 2 USBs hub, so not sure if Body Computer is checking the hardware and automatically setting back the Type 2, or if the configuration change has to be done changing any byte, or if just changing the setting would be enough.
Does anyone any clue? has anyone tried this?
Some pictures to let you know better what I'm talking about
2 USBs in Abarth 595
Re: 2 USBs in Abarth 595
Hmm. Pictures were not uploaded
https://ibb.co/SQWVz40
https://ibb.co/dWtMrRc
