Page 1 of 2
(NIT/NCV) FAILED! - Timeout error
Posted: 18 Oct 2022, 13:50
by misc0
I'm trying to perfom a proxi aligment on my Fiat Bravo 1.6 Easy Multijet. (Not sure if need to choose Fiat 07 or 2014)
Everything works fine except this error: Writing to module: Info-Telematic/Convergence Node (NIT/NCV) FAILED! - Timeout error
I removed the blue&me computer because of battery draining so after remove this ODO start blinking all time. Trying to perfom a proxi aligment to remove the ODO blink.
Any idea about why I'm having this error: Writing to module: Info-Telematic/Convergence Node (NIT/NCV) FAILED! - Timeout error???
Thank you.
Re: (NIT/NCV) FAILED! - Timeout error
Posted: 22 Oct 2022, 10:16
by chrener
As you said Blue&me is removed... This is Convergence Node...
What did you do with proxi? Just alignment or did you try some settings?
Send your configuration and we will see more...
Posted: 23 Oct 2022, 22:17
by misc0
chrener wrote:
22 Oct 2022, 10:16
Thanks for your reply.
I followed this tutorial: https://www.youtube.com/watch?v=RD__7upfeaw
Replaced values:
Steering wheel buttons: "Type B, 8 Buttons" to "Type A, 6 buttons, no CTM"
Auxiliary audio input: "Enabled" to "Not enabled"
Audio output: "Stereo audio/CAN tel.mute" to "Mono audio/analog tel.mute"
Blue&me was draining the battery so I removed it. Tried to run the proxi aligment with Blue&me pluged in but I get the same error.
LOG:
CAN CONFIGURATION DATA:
05 00 84 4F 05 00 84 4F 01 00 04 03 00 00 00 01 00 00 00 00
05 00 84 4F 04 00 04 89 05 00 84 4F 04 00 04 89 04 00 04 09
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 89 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 00 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Side Acceleration / Yaw Node (NYL)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
18/10/2022 16:26:55
Fiat Bravo 2014 1.6 Multijet 16V
Info-Telematic/Convergence Node (NIT/NCV): -
Side Acceleration / Yaw Node (NYL): Ok
Parking Sensor Node (PAM/NSP): Ok
Airbag Node (NAB/ORC): EOL Ok
EXECUTING ADJUSTMENT...
PROXI ALIGNMENT PROCEDURE
FAILED TO EXECUTE
Posted: 24 Oct 2022, 08:42
by shpuncik
disconnect B&M module and do proxi alignment then. choose Bravo '07
Posted: 26 Oct 2022, 08:29
by misc0
shpuncik wrote:
24 Oct 2022, 08:42
B&M module is disconnected. I get the same error even when is connected, looks like B&M computer is broken.
Is there any way to disable/disconnect B&M module from MES before run the proxi alignment??
Posted: 31 Oct 2022, 19:36
by chrener
Hi!
Try this config:
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 09 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 00 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
Posted: 05 Nov 2022, 17:56
by misc0
chrener wrote:
31 Oct 2022, 19:36
Hi!
Try this config:
How can I change this?
Posted: 07 Nov 2022, 08:48
by chrener
Hi!
Run MES / Body / Proxi / Adjustments
Press Alt+Ctrl+C and save your current setting in to file!
Copy my setting and paste it to tab...
Run proxialignment procedure...
Posted: 08 Nov 2022, 20:36
by misc0
chrener wrote:
07 Nov 2022, 08:48
Hi!
Done, but I'm still getting same error :cry:
Executed as Fiat Bravo 2014 1.6 Multijet 16V:
05 00 84 4F 05 00 84 4F 00 00 00 03 00 00 00 01 00 00 00 00
30 34 31 39 38 30 31 34 36 32 30 4F 55 54 50 55 54 2D 4A 49 54 20 14 05 06 4F 84 00 05 89 04 00 04 C1 01 00 07 8F 50 16 00 00 02 84 06 01 28 01 2E C0 81 00 73 00 54 00 00 00 00 00 00 00 00 36 41 05 0C 01 00 00 00 3A 10 28 00 00
08/11/2022 15:17:51
CUSTOM PROXI NEW DATA:
FAILED TO EXECUTE
Executed as Fiat Bravo '07 1.6 Multijet 16V:
05 00 84 4F 04 00 04 09 05 00 84 4F 04 00 04 89 04 00 04 09
08/11/2022 15:20:35
FAILED TO EXECUTE
Posted: 09 Nov 2022, 20:04
by misc0
Proxi alignment failed, but ODO stop blinking!!!!
Looks like this config worked.
Problem solved, thank you so much!
