Problem with connection on module
General messages
dusan147
Post by dusan147 » 27 Jul 2022, 13:11
I use MES 4.9 in combination of USB ELM327 and WiFi ELM327 (1.4 both) and blue (No.5) and gray (No.6) adapter cables for diagnostic of my Alfa Giulia 2.2 MultiJet 16v. USB interface is modified in a way described in a forum for avoid of problems in communication.
I can't to connect to ABS "Torque vectoring module (TVM)" even once. Same error (Connection failed...) appears every time.
Both interfaces works fine with other modules and with blue and gray adapter cables.
What could be source of problem?
Being Merlin and not Arthur!
shpuncik
Re: Problem with connection on module
Post by shpuncik » 27 Jul 2022, 15:28
you can't connect to TVM because you don't have it. TVM is only installed on QV models
dusan147
Post by dusan147 » 27 Jul 2022, 16:05
When I goes to "Alfa Romeo Giulia 2.2 MultiJet v16" and to "ABS" module I can choice "Torque vectoring module (TVM)" as in picture below. Is it some bug, maybe?
shpuncik
Post by shpuncik » 27 Jul 2022, 16:26
maybe Yani didn't sort them and put everything together.
if not sure you can always press Scan F11 to see which modules your car has.
dusan147
Post by dusan147 » 27 Jul 2022, 16:34
Good idea... I will try this. MES will list all modules and submodules?
Btw, my 2.2 Giulia is Veloce with Q4 and AT8.
shpuncik
Post by shpuncik » 27 Jul 2022, 16:44
dusan147 wrote:
27 Jul 2022, 16:34
...MES will list all modules and submodules?
yes. of course you'll have to use blue and gray adapters too.
doesn't matter, still no TVM ;)
Gazum123
Post by Gazum123 » 02 Oct 2023, 19:22
Sorry to bump an old thread but I have this same issues.
I have a 2017 Alfa Romeo Giulia Super with the performance pack (adaptive supension, lsd and paddles)
Just done a service on the lsd and can’t access the TVM module same issue as described here any ideas ?
shpuncik
Post by shpuncik » 05 Oct 2023, 08:07
Gazum123 wrote:
02 Oct 2023, 19:22
mate, have you even tried to read thread? there is clear answer right there why TVM is not accessible to you.
