rear camera after uconnect swap
Posted: 27 Jan 2022, 06:52
by mokumaniak
Hi all,
i will align the proxy on my 500x 1.4 140cv after uconnect swap (6.5 to7)
how to enable thev rear camera?
thank you 4 your help
Re: rear camera after uconnect swap
Posted: 01 Feb 2022, 20:41
by chrener
Check in engineering menu in RVC status if your U7 have RVC support...
Posted: 02 Feb 2022, 11:53
by mokumaniak
thx look on this picture, in Engineering mode RVC config is in grey not in white
I can't go to the RVC config
Only basic Data (FW number)
https://1drv.ms/u/s!AhaD6GepAxliljvsCHN6GoGHNAIj?e=xPagop
Posted: 07 Feb 2022, 18:02
by mokumaniak
it's ok
my fiat 500X with uconnect 6.5
I brougth an uconnect 7 (version 500X 2020) with double USB (it's important) on Ebay.
When i mounted it on my 500X (2016)
Milage flash and rear camera have disappeared
With multiecuscan + blue and grey plug, i realign the proxy with a custom.......
My new Uconnect 7 works fine with activation of carplay.
Posted: 22 Jun 2022, 17:32
by arma500x
anchio sono passato da uconnect 6.5 al 7 e solo la telecamera non compatibile con il 7 va cambiata
[S130 moderator]
I also switched from uconnect 6.5 to 7 and only the camera not compatible with the 7 should be changed‎
