Fiat 500e 2016 cornering light
Posted: 17 Jan 2022, 14:58
by Sporting500e
Can some one tell me the byte or bytes to be changed for cornering lights on the fiat 500e 2016 usa model :D
Re: Fiat 500e 2016 cornering light
Posted: 17 Jan 2022, 21:35
by abarthmultijet
Have find this in forum archive: (for regular fiat 500)
Byte 58 -> 50 - cornering light
Byte 59 -> D9 - cornering light
Posted: 17 Jan 2022, 22:16
by shpuncik
regular Fiat 500 should use byte 42:
xx0xxxxx - without cornering lights
xx1xxxxx - with cornering lights
Posted: 18 Jan 2022, 10:52
by Sporting500e
shpuncik wrote:
17 Jan 2022, 22:16
so i change byte 42 to 00 is no cornering light and byte 42 to 10 is with cornering light ??
mine byte 42 is now 80
Posted: 18 Jan 2022, 11:06
by shpuncik
Sporting500e wrote:
18 Jan 2022, 10:52
shpuncik wrote:
17 Jan 2022, 22:16
read about hex/binary conversions.
if your byte 42 is "80" (hex) = "10000000" (bin) you change it to "A0" (hex) = "10100000" (bin)
PS sometimes cornering lights don't work, not sure why.
Posted: 18 Jan 2022, 15:10
by Sporting500e
shpuncik wrote:
18 Jan 2022, 11:06
Sporting500e wrote:
18 Jan 2022, 10:52
shpuncik wrote:
17 Jan 2022, 22:16
Do you also know the byte to be changed for rvc in u connect 7
Posted: 24 Jan 2022, 10:34
by Sporting500e
Sporting500e wrote:
18 Jan 2022, 10:52
shpuncik wrote:
17 Jan 2022, 22:16
When i change byte 42 into A0 also byte 121 changes from 44 into C4
Posted: 09 Feb 2022, 19:39
by alessandrosx
ciao, non puoi abilitare il cornering light sulla 500, perchè manca l'hardware
(By Mod) ‎hello, you can not enable the cornering light on the 500, because the hardware is missing‎
