Repeated failed forced regens - limp mode
General messages
abarthmultijet
Re: Repeated failed forced regens - limp mode
Post by abarthmultijet » 11 Dec 2021, 17:52
Shame you drilled a hole to the dpf, if you connect the differential sensor hose with a t-piece both to the first connection there should not be a need to drill a hole.
Sheffy
Post by Sheffy » 17 Dec 2021, 16:12
Any idea why it's in limp mode still with no EML or DCTs?
Also any idea why it won't regen? Bad software for this ECU or is it a parameter that is out?
shpuncik
Post by shpuncik » 17 Dec 2021, 16:36
Sheffy wrote:
17 Dec 2021, 16:12
maybe someone already "tuned" ECU and that's why you don't see any DTC?
OFF.PAVAN
Post by OFF.PAVAN » 17 Dec 2021, 17:34
Sheffy wrote:
17 Dec 2021, 16:12
if modded ecm try to downgrade to the original and check wich DTCs send out, May be someone turn off faults codes
Sheffy
Post by Sheffy » 18 Dec 2021, 17:29
I meant I wonder if it's a bug with MES?
The ECU map is very likely to be stock as it's previously thrown up codes for EGR and DPF.
Can anything else cause limp mode without a fault code? If the car had previously failed to regen a number of times and then went into limp mode with "engine failure" EML DPF light etc, would this then require a successful forced regen to get out of limp mode?
shpuncik
Post by shpuncik » 18 Dec 2021, 18:29
take it for a drive on highway - warm up engine, speed at least 60km/h, rpm at least 3000 and drive for about 10-15km in such conditions. should burn and clean DPF if it's clogged to much.
