Giulia Non QV Race Mode
General messages
BoDukeDave
Post by BoDukeDave » 03 May 2021, 14:14
I recently enabled race mode using a QV DNA switch and MES.
I can turn the traction and stability control off and the button lights up as RACE.....as it all should.
I was wondering if anyone knew how to also add the Race Mode Entertainment system graphic (Says Race when selected).
I've also read about some other bits it does on the HUD, eg. Make the speedometer bigger etc. Not sure how true.
Any knowledgeable people achieved this previously? Is it a specific firmware, can it be done?
chrener
Re: Giulia Non QV Race Mode
Post by chrener » 07 May 2021, 18:06
Can You share your proxi please?
I will check if it was correctly changed...
BoDukeDave
Post by BoDukeDave » 13 May 2021, 15:32
Hi, I assume you mean my PROXI allignment log file, if so, please see below.
After further research, it could be only the later models that do this with the larger display screen. Mine is a Giulia 2017.
CAN CONFIGURATION DATA:
4F 0C 40 45 10 00 01 02 02 00 00 00 80 00 00 00 4F 0C 40 45 10 00 01 02 02 00 00 00 80 00 00 00 40 04 00 00 10 00 00 00 00 00 00 00 80 00 00 00 00 00 00 00 10 00 00 00 00 00 00 00 00 00 00 00
4F 0C 40 45 10 00 01 02 02 00 00 00 80 00 00 00 4B 0C 00 45 10 00 01 02 02 00 00 00 80 00 00 00 4F 0C 40 45 10 00 01 02 02 00 00 00 80 00 00 00 4B 0C 00 45 10 00 01 02 02 00 00 00 80 00 00 00 4B 0C 00 45 10 00 01 02 02 00 00 00 80 00 00 00
30 34 36 32 30 30 35 33 36 35 39 4F 55 54 50 55 54 2D 53 49 54 20 17 07 19 4F 0C 40 45 10 00 01 02 02 00 00 00 80 00 00 00 4B 0C 00 45 10 00 01 02 02 00 00 00 80 00 00 00 4B 59 2F 01 A9 01 07 F3 50 31 81 07 79 10 10 0A A3 1E 04 52 00 35 73 14 01 4F 03 B4 18 83 EC 24 11 23 07 00 80 00 0C 4E 00 00 19 04 00 09 02 5B FA 05 06 E5 05 31 00 01 70 14 3D 89 10 05 00 CA 00 B7 10 11 00 3D 49 03 03 12 F8 47 80 00 00 01 00 00 F0 20 04 1E 81 0A 00 00 00 00 00 0C 1C 00 00 00 00 30 00 00 00 03 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Body Computer Node (BCM/NBC)
Engine Control Node (ECM/NCM)
Dashboard Node (IPC/NQS)
Automatic Transmission Node (TCM/NCA/NCR)
Gearbox Selector Node (ESM/GSM/NSC)
Driver Assistant System Node (DASM)
Radio Frequency Hub Node (RFHM)
Comfort Seat and Wheel Node (CSWM)
Entertainment multimedia control module (EMCM)
Parking Sensor Node (PAM/NSP)
Airbag Node (NAB/ORC)
Haptical Lane Feedback Node (HALF)
(Multiecuscan 4.6R1)
02/05/2021 16:47:45
Alfa Romeo Giulia 2.0 Turbo 16V MultiAir
CAN Setup / PROXI Alignment Procedure (952)
Engine Control Node (ECM/NCM): EOL Ok
Automatic Transmission Node (TCM/NCA/NCR): EOL Ok
Gearbox Selector Node (ESM/GSM/NSC): Ok
Driver Assistant System Node (DASM): EOL Ok
Radio Frequency Hub Node (RFHM): EOL Ok
Entertainment Telematic Node (ETM): EOL Ok
Comfort Seat and Wheel Node (CSWM): EOL Ok
Entertainment multimedia control module (EMCM): EOL Ok
Brake System Node (ABS/BSM/NFR): EOL Ok
Parking Sensor Node (PAM/NSP): EOL Ok
Airbag Node (NAB/ORC): EOL Ok
Haptical Lane Feedback Node (HALF): EOL Ok
EXECUTING ADJUSTMENT...
Daylights dropout
Old value: Enabled
New value: Disabled
COMPLETED
chrener
Post by chrener » 20 May 2021, 20:11
Try to change BYTE 88 from EC to CC and run proxi alignment.
BoDukeDave
Post by BoDukeDave » 15 Jun 2021, 20:29
Thanks for the response,
I'm an IT Manager so competent with the technology, but I don't even know where to start with changing bytes.
Could you give me a step by step guide or some pointers?
Could you give me a little more background behind this change? What you expect it to do and why?
