Do I have to pay $50 for someone to Help me here?
General messages
Abarther193
Post by Abarther193 » 07 Jan 2021, 16:20
Jesus no one responds here whats the point of this forum, if that's the case I'll pay anybody that can help me solve my issue.
alex-et3
Re: Do I have to pay $50 for someone to Help me here?
Post by alex-et3 » 07 Jan 2021, 20:49
Qual é il tuo problema?
Abarther193
Post by Abarther193 » 07 Jan 2021, 21:16
I have a 2013 fiat 500 (American Model) and I replaced my stock cluster with a 2014 prestyling tft digital cluster with blue & me connect so I got the exact one needed. I purchased the complete multiecuscan kit with cables and registered software and followed all the instructions......Body connect ......in the next screen
cont, alt C for or hidden proxy settings screen.......byte 65 ..00 to 60 press ok ...Go to proxy ailing and execute...turn the car off when finished wait a minute then turn the car back on and NOTHING still the same base 500 mode (00) but when i go to check the proxy the 60 is still there so I'm stuck with the crappy 500 cluster theme.
alex-et3
Post by alex-et3 » 07 Jan 2021, 21:22
most likely the proxy alignment is not successful in the tft. it will be an elm interface problem. the same problem happened to me on a UCONNECT. Don't have another diagnosis program?
Abarther193
Post by Abarther193 » 07 Jan 2021, 21:36
Like which one? I'm using MES.
Abarther193
Post by Abarther193 » 07 Jan 2021, 21:45
I'm using the red elm interface that came with the MES kit? So the one they provided doesn't have the mod already on it....the 120 pin removal?
alex-et3
Post by alex-et3 » 07 Jan 2021, 22:03
Abarther193 wrote:
07 Jan 2021, 21:36
try going to a repair shop and having proxy alignment done
Abarther193
Post by Abarther193 » 07 Jan 2021, 22:10
In mes it says that everything is configured properly and that it's not necessary when I connect to the car though and my milage is not flashing anymore, it was when I first connected it but not now.
alex-et3
Post by alex-et3 » 07 Jan 2021, 22:18
Abarther193 wrote:
07 Jan 2021, 22:10
he said so to me too ....
Abarther193
Post by Abarther193 » 08 Jan 2021, 02:22
So you went to a dealer or to your mechanic?
