Page 1 of 2
CRUISE CONTROL ABARTH 595/FIAT500 RESTYLING 2016
Posted: 08 Nov 2020, 17:46
by matte595
Hello everyone, I open this topic to seek help regarding the activation of the cruise control on abarth 595 / fiat 500 restyling. The machine has the wiring prearranged and I bought the original lever which fits perfectly. I attach photos
I have multiecuscan 4.6R1 and enabling the cruise control function in proxy alignment gives no signs of operation.
I ask if anyone knows the bits to change in custom proxy (CTRL + ALT + C) in order to enable the cruise control function. I'm sure it works differently there would be no wiring in the column.
THANKS TO ALL IN ADVANCE FOR THE HELP
ABARTH 595 145CV 2016 - RESTYLING
BODY COMPUTER
CODICE ISO: 00 60 15 14
N.RO DISEGNO FIAT: 0312N6EU201
N.RO SOFTWARE: 28544558
MY CUSTOM PROXY WITH UCONNECT 7 CARPLAY/ANDROID AUTO
33 32 31 35 30 30 31 39 33 39 32 4F 55 54 50 55 54 44 4A 49 54 20 16 06 17 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 77 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 01 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 94 08 52 00 04 88 02 00 20 80 00 00 44 00 F1 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Buongiorno a tutti, apro questo topic per cercare aiuto relativamente l'attivazione del cruise control su abarth 595/fiat 500 restyling. La macchina ha il cablaggio predisposto e ho acquistato la leva originale che monta perfettamente. allego foto
Ho multiecuscan 4.6R1 e abilitando la funzione cruise control in allineamento proxy non da segni di funzionamento.
Chiedo se qualcuno conosce i bit da modificare in custom proxy (CTRL+ALT+C) per poter abilitare la funzione cruise control. sono sicuro che funzioni diversamente non ci sarebbe il cablaggio nel piantone.
GRAZIE A TUTTI IN ANTICIPO PER L'AIUTO
Re: CRUISE CONTROL ABARTH 595/FIAT500 RESTYLING 2016
Posted: 23 Nov 2020, 17:10
by chrener
Hi!
Try to change byte 92 from 00 to 01. Lever is only with CC or also with Speed Limiter? There were 3 wires in car connector? THX...
Posted: 23 Nov 2020, 18:55
by matte595
i try to change byte 82 in 01, 07 and 09 but it not worked.
i will try the byte 92 for last chance.
The lever is the original with Cruise and speed limiter, and the connector have 3 wires; thanks
Posted: 23 Nov 2020, 20:18
by matte595
chrener wrote:
23 Nov 2020, 17:10
Hi!
i tried to activate byte 92 from 00 to 01 but it doesn't work anyway
:roll: :roll: :roll:
Posted: 24 Nov 2020, 21:28
by chrener
Ok, try to change byte 82 to 03
Posted: 27 Nov 2020, 17:06
by matte595
i will try but not work and not displayed on tft
Posted: 18 Dec 2020, 23:00
by Scealmor
Hi matte595
I am.trying the same thing at the moment. Have bought a used 500 crusie control stalk. Will attempt to install.need week.
I can't see a crusie light/speed limiter symbol on the TFT cluster display.....
My body computer is
Posted: 19 Dec 2020, 08:46
by Scealmor
Bcm and TFT details in the pics
I think the TFT panel is not compatible with cruise, I'm trying to find out if a later 2019 fiat 500 has the cruise symbol on it
Posted: 08 Mar 2021, 12:59
by Mariano
No one say anything , is MTX o ATX ?, because the bytes are differents.
Posted: 13 Mar 2021, 15:25
by chrener
Cruise control works? Without icon on instrument cluster? Or it doesnt work anaway?
