changing uconnect 3.5 "radio to 5" nav
General messages
dreamumut
Post by dreamumut » 29 Dec 2019, 13:44
Hi all,
i have change factory 3.5 "uconnect to 5" nav and do proxi everything work but i cant use usb port on uconnect also cant update firmware because usb failure ...
any idea?
1.4 95hp stock
my proxi ;
33 36 33 35 36 30 32 38 35 36 36 4F 55 54 50 55 54 44 4A 49 54 20 18 01 29 4F 04 00 04 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 04 10 00 00 00 00 00 00 00 00 00 00 00 40 59 04 01 A4 10 07 87 A0 24 01 07 42 10 00 03 A3 28 00 01 01 05 00 14 00 01 03 00 01 43 08 00 0C 00 00 00 80 00 00 00 00 00 30 81 00 25 10 5A 00 C6 02 A5 00 11 00 01 92 12 00 40 00 01 01 40 00 01 00 11 00 00 49 00 01 14 10 42 00 00 00 01 00 00 70 00 01 1C 80 00 C0 00 00 00 00 00 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
DGinUK
Re: changing uconnect 3.5 "radio to 5" nav
Post by DGinUK » 30 Mar 2020, 12:21
hi
did you get a solution to your issue in the end? was the cable seated correctly at the back of the unit. In in the process of going from 5in uConnect to 7 in uConnect and i can see on the back of the unit the grey square connector is essentially a mini USB which i presume is just extended to the one in the car? just a guess
cheers
Yugiro
Post by Yugiro » 19 Jul 2020, 09:18
did you find a solution to this problem
