Page 4 of 8
Re: Uconnect 7" fiat tipo enable DAB
Posted: 28 Apr 2019, 15:43
by sabath21
Is there someone on this forum who has only DAB or NAV enabled and can share the proxy?
Today I tried to modify byte 121 from "C3" to "C7" and byte 123 from "91" to "D5" but I still got an error message "request of data range" at the telematic node.
Posted: 29 Apr 2019, 07:17
by devist
sabath21 wrote:
28 Apr 2019, 15:43
this configuration have all enabled.. fiat tipo 1,4 tjet 120HP Lounge, Pack Tech, Pack Safety, Pack Comfort NAV DAB etc..
33 36 33 35 36 30 34 39 30 34 35 4F 55 54 50 55 54 44 4A 49 54 20 17 04 19 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 51 F9 05 01 A4 14 07 87 B0 29 07 07 42 10 00 03 A3 1E 04 02 01 35 63 14 00 4F 03 34 1B 83 08 00 23 00 05 00 80 00 00 00 00 00 10 81 00 25 01 5A 00 64 04 A5 00 4E 00 01 A1 10 00 40 00 01 00 C7 00 D5 00 00 00 00 49 01 01 14 70 62 00 00 00 01 00 80 70 00 01 1B C0 00 80 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Posted: 29 Apr 2019, 09:35
by sabath21
devist wrote:
29 Apr 2019, 07:17
sabath21 wrote:
28 Apr 2019, 15:43
It's quite difficult to find what what bytes are for NAV/DAB because the proxy contains all of the additional tech packs. Anyway, good to have that proxy for comparison. Anyone else having NAV/DAB enabled only without adaptive cruise, brake assist?
What contains Pack Tech, Pack Safety, Pack Comfort? It seems that pack names are different for each country.
Posted: 29 Apr 2019, 11:04
by Robertoto
In my tipo my 2019 1.3 multijet lounge
Pack city: retro cam, light sensor, rain sensor, interior automatic mirror, park sensor
Pack safety plus: speed limiter, full brake control, adaptive cruise control
Posted: 29 Apr 2019, 17:06
by Robertoto
i.m.h.o there is a a line in the proxy code that changes between the motor ,too. so we have to distinguish the part of code that is for motor-type and the part that is for equipment-type
secondo me nel codice proxy ci sono differenze anche in base al tipo di motorizzazione. quindi dobbiamo distinguere anche la parte relativa al motore e quella al equipaggiamento
Posted: 29 Apr 2019, 17:18
by Robertoto
devist senza nav/dab
33 36 33 35 36 30 31 33 35 30 32 4F 55 54 50 55 54 44 4A 49 54 20 18 07 27 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 51 F9 05 01 A4 14 07 87 B0 29 07 07 42 10 00 03 A3 1E 00 02 01 35 63 14 00 4F 03 34 1B 83 08 00 23 00 05 00 80 00 00 00 00 00 10 81 00 25 01 5A 00 64 04 A5 00 4E 00 01 A1 17 00 40 00 01 00 C3 00 91 00 12 00 00 49 01 01 14 50 62 00 00 00 01 00 00 70 00 01 1B C0 00 80 00 04 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
devist con nav/dab
robertoto senza nav/dab
33 36 33 35 36 30 32 38 36 34 38 4F 55 54 50 55 54 44 4A 49 54 20 18 09 04 4F 04 00 05 10 02 00 02 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 02 00 00 00 00 00 00 00 00 51 F9 05 02 A4 14 07 87 90 29 07 07 42 10 00 03 A3 28 00 82 01 35 63 14 00 4F 03 34 1B 83 08 00 27 00 05 00 A0 00 00 00 00 00 08 A1 00 25 01 5A 00 64 04 AD 00 4E 00 01 A1 17 00 40 00 01 00 C3 00 91 00 12 00 00 49 01 01 14 50 62 00 00 00 01 00 80 70 00 01 25 C0 00 80 00 04 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Posted: 29 Apr 2019, 18:12
by Robertoto
Ci sono uguaglianze tra la proxy mia e le 2 proxi devist, uguaglianze tra le 2 di devist e differenze tra le 2 proxy di devist. Vi farò una relazione e vediamo se ne veniamo a capo.
Posted: 29 Apr 2019, 19:39
by sabath21
Ok. Today I tried AlfaOBD software. I set DAB presence to Enable and it seems byte 123 is affected when it comes to DAB function. Byte 123 for my configuration is "91", for DAB it's "95' For proxy allignment I used MES but it failed at entertainment telematic node. Now, I don't know if it's MES fault or my unit doesn't have DAB at all. I doubt so...
Below is the proxy after DAB enablement:
33 36 33 35 36 31 32 39 31 33 30 4F 55 54 50 55 54 44 4A 49 54 20 18 08 26 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 87 A0 24 01 07 42 10 00 03 A3 1E 00 02 01 35 63 14 00 4F 03 34 01 43 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 10 5A 00 9D 06 A5 00 4E 00 01 92 17 00 40 00 01 00 C3 00 95 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 01 1C C0 00 C0 00 04 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Proxy without DAB
33 36 33 35 36 31 32 36 32 30 35 4F 55 54 50 55 54 44 4A 49 54 20 18 08 26 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 4F 04 00 05 10 00 00 00 00 00 00 00 00 00 00 00 50 D9 05 01 A4 10 07 87 A0 24 01 07 42 10 00 03 A3 1E 00 02 01 35 63 14 00 4F 03 34 01 43 08 00 0C 00 02 00 80 00 00 00 00 00 30 81 00 25 10 5A 00 9D 06 A5 00 4E 00 01 92 17 00 40 00 01 00 C3 00 91 00 12 00 00 49 00 01 14 50 42 00 00 00 01 00 00 70 00 01 1C C0 00 C0 00 04 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80
Posted: 29 Apr 2019, 20:29
by alex-et3
Robertoto wrote:
29 Apr 2019, 17:06
Si si,certo!Diciamo che la parte che riguarda l uconnect parte dal byte 121 in poi,almeno su 500,500L,Ypsilon...
Posted: 29 Apr 2019, 20:38
by sabath21
Maybe someone else who doesn't have DAB can try to change the byte 123 to "95"? Maybe my elm327 is broken?
