Uconnect 7" fiat tipo enable DAB
General messages
brucer03
Re: Uconnect 7" fiat tipo enable DAB
Post by brucer03 » 16 Dec 2020, 10:43
Ricevo un errore anche con proxi di fabbrica (backup). Com'è possibile?
alex-et3
Post by alex-et3 » 16 Dec 2020, 11:57
Ma spiega che hai fatto alla vettura...perché non vedo il motivo di fare un allineamento proxy se non hai cambiato centraline...
brucer03
Post by brucer03 » 23 Dec 2020, 10:49
alex-et3 wrote:
16 Dec 2020, 11:57
Ho provato ad attivare carplay
devist
Post by devist » 30 Jan 2021, 19:41
ciao a tutti ..qualcuno s a come abilitare la porta AUX ?? provato con MES e ALFAOBD ma non si abilita..con le varie configurazioni veicolo combinazioni AUX , AUX USB, AUX USB SD, AUX USB1SD USB2 m anon cambia nulla .
ho sostituito il pannellino solo USB con un altro AUX USB il cablaggio è lo stesso e i fili sono tutti collegati alla radio..
JulienK
Post by JulienK » 08 Sep 2021, 20:16
Hello everyone,
I have read all the comments here,
here I am busy on a late 2018 abarth, which 7inch screen has DAB, carplay/AA and Beats
I am trying to change the coding to enable navigation,
I have the Byte 121: 70, I modified it to 40 and 44 but no change, (the abarth has the Beats option, so for me it would be 44)
I do not understand why it does not work, when I have already changed, on another abarth, the car radio 5inch -> 7inch, I was able to activate the NAV and DAB without problem.
Of course, I have the receiver box for the NAV.
if you have any idea how to make NAV work and activate it, I will be grateful !!
This my dump :
33 32 31 35 30 30 34 39 33 35 33 4F 55 54 50 55 54 44 4A 49 54 20 19 03 14 4F 84 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C7 75 06 FE 00 1C C0 00 00 00 16 00 01 00 94 06 01 01 00 40 00 02 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 15 00 94 08 52 30 04 95 00 00 20 80 00 00 70 00 95 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 44 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
