Is there a setting in the TFT cluster module for hill start assist?
I installed a 2015 TFT cluster in my 2012 but lost hill start assist.
It's turned on in the menu of the cluster.
I updated byte 65 to 60 (which looks much better), engaged the hazard illumination on deceleration, and also disengaged the seat belt chime.
Is there is a way to quiet down the chimes? The turn signal noise is a lot louder in the TFT cluster.
Any chance Yani can get access to shutoff the horn beep when you lock the doors so we only have lights flash? I'll gladly pay for that feature.
US 2012 Abarth with 2015 TFT
Re: US 2012 Abarth with 2015 TFT
There's an alternate way of disabling the horn - if you disconnect the stock horn and install an air horn, the brief pulse upon lock isn't enough to actually sound the horn, and it locks silently.
Hi. I am interested in learning how to turn off the seat belt chime. How is this accomplished?
check in instrument cluster, usually there is option to disable it.MRCOOLDUDE wrote: ↑10 Oct 2023, 22:37Hi. I am interested in learning how to turn off the seat belt chime. How is this accomplished?
I have looked, several times. There is not. I think this option is perhaps available on newer or older models of the car. I have the 2013 version. I was hoping there was some way to do this with MES and I have been informed that there is.
Go to dashboard -> instrument panel (which is the right one for you) -> adjustments -> deactivate seatbelt allarmMRCOOLDUDE wrote: ↑11 Oct 2023, 14:52I have looked, several times. There is not. I think this option is perhaps available on newer or older models of the car. I have the 2013 version. I was hoping there was some way to do this with MES and I have been informed that there is.
