Page 6 of 10
Posted: 27 Mar 2023, 20:29
by kanada_green
So I have been trying to do proxy allignemt with my uconnect 7 for the past few days
I have a 2020 Abarth 595 - manual, no sunroof, no cruise, no dusk, no rain sensors
carplay works, I have GPS but no NAVI and also the radio station name don't display
And I'm keeping getting an ETM error B222C-00
And when i do proxy allignment it says - ETM failed - request out of range error
Body Computer Delphi (312)
ISO Code: 00 00 60 15 14
Errors found:
B10AA-4A - PROXI configuration control
U1733-87 - Convergence Telematic Node (L1 and L2)
33 32 31 35 30 30 35 35 38 30 36 4F 55 54 50 55 54 44 4A 49 54 20 20 02 06 4F 04 00 05 02 00 00 00 09 00 00 04 02 00 00 00 81 C2 35 06 FE 00 1C C0 00 00 00 16 00 01 00 85 06 01 01 00 40 00 02 20 75 40 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 8C 00 84 08 52 00 00 88 00 00 20 00 00 00 44 00 15 00 0F 00 00 00 80 05 00 80 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 08 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
can someone guide me in the right direction?
Posted: 29 Mar 2023, 19:11
by chrener
JMM wrote:
27 Mar 2023, 13:50
Hi everybody,
I connected my new Uconnect 7 instead of my previous radio Uconnect 5
The problem that I, it's impossible to get Carplay, evrything work well, it's a new Uconnect 7 working well (Except for my Fiat 500 1.2 8V :evil: ) with DAB Touch CARPLAY 2020 when I bought it in Italy.
I tried many tests but without success.
Please find herewith my proxy report:
33 32 31 35 30 30 32 33 34 37 37 4F 55 54 50 55 54 44 4A 49 54 20 16 11 22
4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 81 C2 73 06 F4 00 1C C0 00
00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00
00 00 00 31 05 11 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 47 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 05 00 0F
00 00 00 00 01 00 C0 01 00 00 00 00 00 80 00 00 00 00 00 00 00 00 05 00 00
00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
00 00 00 00 00 00 00 00 00 80
Body Computer (BCM/NBC)
Contrôle Moteur (ECM/NCM)
D.A. électrique (EPS/NGE)
Tableau bord (IPC/NQS)
Dispositif de freinage (ABS/BSM/NFR)
Noeud Embardée/Accélérat. Latérale (NYL)
Noeud Capteur Stationnement (PAM/NSP)
Noeud Air Bag (NAB/ORC)
(Multiecuscan 5.1)
27/03/2023 15:01:15
Fiat 500 1.2 8V
Body Computer (BCM/NBC) EOL Ok
Contrôle Moteur (ECM/NCM) Ok
D.A. électrique (EPS/NGE) Ok
Tableau bord (IPC/NQS) EOL Ok
Dispositif de freinage (ABS/BSM/NFR) Ok
Noeud Embardée/Accélérat. Latérale (NYL) Ok
Noeud Capteur Stationnement (PAM/NSP) Ok
Noeud Air Bag (NAB/ORC) EOL Ok
Entertainment Telematic Node (ETM) EOL Ok
ATTENTION Ce véhicule est correctement configuré. L’alignement PROXI n'est pas nécessaire
Regarding this proxy, somebody may help me to resolve this problem : No Carplay activate
Many for your help :P
Send photo of radio label,
Did you change USB port?
Posted: 30 Mar 2023, 18:09
by JMM
Hi Chrener,
My Uconnect is a Continental FIAT 312 7" vp2 ECE DAB NAV
Date: 09.11.20
SW Version: 23.02.41.13
HW Version: F.EU.D7.V27
OEM: 735743701 5753
My USB it's a native one
Thks for your comments
Posted: 02 Apr 2023, 10:37
by chrener
I am sorry but your Uconnect is without carplay support
Your radio is without 8EW code which means CARPLAY...
As you can see at attached picture...
Posted: 07 Apr 2023, 11:37
by nickvh
Friend of mine has an fiat 500 from 2011 and has aftermarket radio what byte do i need to change to disable blue&me so mileage wont flash anymore?
Posted: 13 Apr 2023, 23:27
by KolyaKex
This is the same way to make a proxy exception, as my described way The only difference is, that you are loosing the transparent proxy conduct.
So Im glad to hear, that this works for you
Posted: 18 Apr 2023, 05:12
by barto46
Thank you
Posted: 19 Apr 2023, 18:27
by Ponto50chips
hello everybody. I have a fiat 500 here and it does not accept proxy alignment. I'm trying to remove the CTM central from convergence and radio to put a pioneer multimedia central. I've done it other times here and it always worked doing the proxy alignment. but here it does not finish and the panel remains blinking.
Fiat 500 2012 manual
I read the bcm proxy and below is the information.
31 32 31 31 33 38 35 31 38 30 30 31 32 33 34 35 36 37 38 39 30 20 11 07 21 6F 80 00 04 02 00 00 00 29 00 00 00 02 00 00 04 00 C 14 00 96 00 09 00 95 03 12 02 1E 01 00 00 00 00 00 00 00 00 45 00 00 00 00 31 06 91 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Posted: 19 Apr 2023, 21:37
by gcelettronica
Hi all I have a Lancia Ypsilon 2014 with classic mp3 car radio I would like to install uconnect 5 inch vp2 dab I changed my proxy Like this
33 32 34 30 32 30 31 30 33 32 39 4F 55 54 50 55 54 44 4A 49 54 20 15 02 27 4F 00 00 05 10 00 00 00 09 00 00 04 10 00 00 00 43 C2 73 06 E5 00 1C 21 A9 00 00 06 00 07 00 8C 06 15 01 28 00 00 91 01 35 40 0A 0C 00 00 20 0E 15 00 00 00 00 33 05 70 00 10 00 04 00 00 20 03 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 64 00 B4 00 00 00 00 00 02 00 00 00 00 00 40 00 A5 00 0F 00 00 49 00 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
complete proxy alignment successfully but keep flashing km and steering wheel controls not work Is anyone so kind that can help me?
Posted: 09 May 2023, 11:35
by MCHL500
I have a (early) 2017 Fiat 500 with Uconnect 7. Currently, CarPlay is not activated. Is it possible to find out if my unit supports CarPlay, using Multiecuscan and proxy alignment? Can I read version details from the display or do I need to take out the head unit to look at the label on the back? Thanks for your support!
