Press on the name of the person en there should be a tab with send private message
Good evening I bought a 2009 500 Abarth to which they replaced the complete dashboard. they mounted uconnect 7inch tft and 2017 steering wheel. now the kilometers are flashing and the steering wheel controls don't work. can you help me with the proxy alignment you are wizards??? a thousand thanks
Hi, my name is Jörg and I have a Fiat 500C 2019. I changed my Uconnet 5 to an Uconnet 7 and it is working great. Last weekend I changes the tacho and I am happy with my new car! The digital tacho is great and is working nice, but I think that the digital tacho do not recognize the Uconnet 7? I have the small menu inside the tacho without Navi and without radio. Have everyone an idea which byte is wrong or what can I do to get the hole functions of the tacho? I can not change the byte 65 to the vallue 20 or 40 to change the graphic of the tacho. If I try this I get an error. Have I to change any bytes? I have no idea. The uconnet radio is working fine.
Thank you very much and best regards
Jörg
33 32 31 35 30 30 34 38 31 35 35 4F 55 54 50 55 54 44 4A 49 54 20 19 01 31 4F 80 00 05 10 00 00 00 09 00 00 04 10 00 00 00 83 47 73 06 F4 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 82 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 74 00 94 00 22 00 04 93 07 00 20 80 00 00 44 00 D5 00 0F 00 00 00 00 05 00 40 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Jörg
Hi Guys,
I am all the time as a silent reader here on the forum and through the entries of you I have managed to upgrade the conversion from normal Uconnect 5" without Nav, DAB etc. to the Uconnect 7" with DAB, Nav, Apple Carplay. Until then, thank you very much!!
I have now also created a custom proxy and the system runs beautifully except that internal TomTom Nav Software.
As mentioned earlier, it is a NAVI Uconnect 7" with DAB. I am completely missing the navigation icon on the bottom bar.
What I had already read from another user is that it may be due to the VIN of the donor vehicle and that you should first rewrite it to the VIN of the current vehicle.
Is this true, or is that not necessary, if so, how i can change the VIN?
Or is it possible to program the proxy so that it works:
Here is my proxy:
33 32 31 35 30 31 36 37 38 32 4F 55 54 50 55 54 44 4A 49 54 20 15 12 03
4F 84 00 05 10 00 00 09 00 00 04 10 00 00 00 83 C2 75 06 F4 00 1C C0 00
00 16 00 01 08 94 06 41 01 00 40 00 81 00 75 41 0A 0C 0D 01 80 2E 24 00
00 00 31 05 61 00 00 04 00 00 00 00 00 00 00 00 00 00 00
I had to extend the proxy to 193 bytes, otherwise the allignement did not run.
I also tried to set both bytes for the Navi setting (40,44), but without any effect on the actual problem.
As hardware I have the OBD 327 with the yellow plug. I also have the full version of the Multiecuscan 5.0.
I would be very happy to receive your answers.
greetings
Auronis
Here is my proxy:
greetings
Auronis
Hi Auronis,
I Had the Same Problem. I changed the Byte 132:
byte 132 -> 70 -> navi on instrument cluster
After that I Had to activate the Navi in MES and after this I Had the Navi Menü at the TFT. After the activation of this from the TFT everything is working perfekt.
The only Problem for me, I can't Change the graphic with Byte 65. If I Change to 20 or 40 or 70 nothing Happens. The graphic ist Like before, the normal Fiat 500 graphics.
Best regards
Jörg
Best regards
Jörg
I've just fitted a tft screen in my twin air and have the same problem with Byte 65, no matter what I set it to it doesn't change the display.
Hi guys, send me your proxy if you want to change the graphic to the abarth version.
I don't need the Arbarth version on mine, just the 500T, I was just hoping to be able to switch between them to see which options it gave me.
I'll note the btyes down and post it up later this evening.
I, I come from spain. Fiat 500c 2018. I change the uconnect 5 w/o navigation w/o carplay for a uconnect 7 ( continental fiat 312 7" vp2 ECE DAB GPS. whit the poxy alignment the carplay is ok, but not show the navigation menu of the ucconnect. No dab antena conected ( dab not show, but no errors en MES)
Uconnect gps is the same that uconnect navi???
My actual proxy :
33 32 31 35 30 30 33 39 37 32 39 4F 55 54 50 55 54 44 4A 49 54 20 18 05 28 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 81 42 73 06 FE 20 1C C0 00 00 00 16 00 01 00 94 06 41 01 00 40 00 00 00 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 05 18 03 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 B1 00 94 00 22 00 04 93 02 00 20 80 00 00 44 00 D1 00 0F 00 00 00 00 01 00 70 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 00 00 00 00 00 00 00 01 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Thanks a lot.
My actual proxy :
Thanks a lot.
Hi!Imago wrote: ↑08 Mar 2023, 18:24I, I come from spain. Fiat 500c 2018. I change the uconnect 5 w/o navigation w/o carplay for a uconnect 7 ( continental fiat 312 7" vp2 ECE DAB GPS. whit the poxy alignment the carplay is ok, but not show the navigation menu of the ucconnect. No dab antena conected ( dab not show, but no errors en MES)
My actual proxy :
Thanks a lot.
No!
GPS is only with Compass
NAV is with Navigation
