Good morning, I activated the fog lights feature in the fiat 500L body.
I noticed that the cornering function does not have menu settings.
I ask if this feature can be activated in the fiat 500L factory out of fog lights.
If you can activate this function you can explain how to do it.
Thank you
To do this I used a multiecuscan version 3.7 with elm 327 interface + adapter 2.
500L activate fog lamp with cornering function
Re: 500L activate fog lamp with cornering function
Good evening, no one in help ........
You can activate the fog lights and have the cornering function, in fact turning on a curved fog lamp as the fiat 500L originates.
I say that I activated the fog lights with correct operation, missing the cornering function (turning on only one curved fog)
You have to ask Yani if you can activate this function.Roberto0187 wrote:Good evening, no one in help ........
Thank you for the reply,alex-et3 wrote:You have to ask Yani if you can activate this function.Roberto0187 wrote:Good evening, no one in help ........
how can i ask yani how can i enable the function in proxy can.
I add that when I did the activation of the fog lights in the proxy, I did not succeed with the last unit I think the car radio.
However, even though it has failed, I activated the fog lights with ignition via the original keyboard only retro-light, now I do not want the problem to be this.
As a proxy writing error I was given time out error.
No, I think there is a special activation to do.Roberto0187 wrote:Thank you for the reply,alex-et3 wrote:You have to ask Yani if you can activate this function.Roberto0187 wrote:Good evening, no one in help ........
then I just have to hope for Yani help.alex-et3 wrote:No, I think there is a special activation to do.Roberto0187 wrote:Thank you for the reply,alex-et3 wrote: You have to ask Yani if you can activate this function.
do I have to wait for a response here or there is a section to make this request?
You have to contact him through MPRoberto0187 wrote:then I just have to hope for Yani help.alex-et3 wrote:No, I think there is a special activation to do.Roberto0187 wrote: Thank you for the reply,
Hi. News? I have same problem in my Fiat Tipo. Thank you.
-----EDIT------
Thanks all. Fiat car service called me some days ago, and i visited the service, and my problem solved. (Fiat Tipo) Now working perfectly like the stock. He tell me, needed to change some 'hidden' settings with programming in the daytime running lights section. And after activated. Similar method like other newer Fiat models settings.
-----EDIT------
