Page 9 of 21
Posted: 03 May 2017, 20:50
by nufan0000
I guess is there a possible way to see if we can disable radio function in multiecuscan? maybe that would help ?
Posted: 03 May 2017, 20:58
by alex-et3
nufan0000 wrote:I guess is there a possible way to see if we can disable radio function in multiecuscan? maybe that would help ?
To disable the radio function, disconnect the radio and also the blue and me control unit and then do the proxy alignment.
You should remove the ecu from the proxy configuration.
Posted: 05 May 2017, 22:05
by nufan0000
I don't have the radio anymore and currently have those Chinese Headunit with a Canbus in it. But is there a option in multiecuscan to disable Uconnect then for the Cluster? I think the mystery is that if we can disable Uconnect from the Cluster it will revert back? Do you know what will happen if you disable all the function like Blue and me and uconnect? Would the speedometer just revert back to factory? I am just askin as just wondering how I can revert the speedometer to factory without finding another car with uconnect.
Posted: 06 May 2017, 09:32
by alex-et3
nufan0000 wrote:I don't have the radio anymore and currently have those Chinese Headunit with a Canbus in it. But is there a option in multiecuscan to disable Uconnect then for the Cluster? I think the mystery is that if we can disable Uconnect from the Cluster it will revert back? Do you know what will happen if you disable all the function like Blue and me and uconnect? Would the speedometer just revert back to factory? I am just askin as just wondering how I can revert the speedometer to factory without finding another car with uconnect.
I can not know, you have to try.
Posted: 09 May 2017, 09:03
by snowbound_sonic
Hi Alex,
Can you post or PM a screenshot of your Custom Proxy data for the TFT graphics in your picture below please?
Grazie
Posted: 09 May 2017, 10:42
by alex-et3
snowbound_sonic wrote:Hi Alex,
Grazie
Of course!
I send you the 500 Abarth proxy code in which your tft was mounted!
Fiat 500 Abarth Restyling:
33 32 31 35 30 30 31 39 31 39 30 4F 55 54 50 55 54 44 4A 49 54 20 16 06 06 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 91 C2 77 06 FE 00 1C C0 00 00 00 26 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 85 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Let me know if you find the byte to configure the new tft graphics.
Posted: 10 May 2017, 10:16
by snowbound_sonic
The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
I'll change that value on my custom proxy and see what happens.
Posted: 10 May 2017, 10:51
by alex-et3
snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
This is not the secret of new graphics.
I have the bodycomputer of a 500 Abarth restyling experimental that still has the old graphics and the byte 65 is always 20.
Posted: 10 May 2017, 18:01
by snowbound_sonic
alex-et3 wrote:snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
What happens if you change Byte 65 to the value 60 using the restyling BCM?
Posted: 10 May 2017, 18:44
by alex-et3
snowbound_sonic wrote:alex-et3 wrote:snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
If I set it to 60, it's always the same as it was at 20 or 30.
These trials, however, have always made them on the bench, not on the car.
