Page 21 of 21
Posted: 03 Mar 2023, 18:23
by budgoz
robi80 wrote: ↑24 Feb 2022, 07:58
hi sorry for my english
One thing I have not yet understood, how to solve the pressure gauge problem and Sport writing always on.
I mounted a tft blue and me on Abarth 2010 and 2 bar pressure gauge of a 2017 competition.
Tft all ok with the limits we know.
Manometer instead written always on even in normal mode.
Can it be solved with multiecuscan or do you need something else?
For the Sport gauge to work properly you need to change byte 49 to C0.
Posted: 25 Jul 2023, 19:39
by SHeva4ever
budgoz wrote: ↑03 Mar 2023, 18:23
Thank you so much. It is finally working now. It also activated the "Shift up^" light in normal mode.
I have a 2012 Abarth with blueme and a new cluster from the restyle model. I've found that my daytime running lights are not working. I can test it using AlfaOBD and multiecuscan (enable it for 10 sec), but I can't enable it permanently. I think it is possible to activate it using a custom proxy. Does anybody know how to enable those DRL ?
Posted: 09 Aug 2023, 07:05
by RainMan1
Wayne74 wrote: ↑18 Nov 2021, 17:35
Hi there is now a fix in multiecuscan 4.8 that let's you set date and time to a TFT clock without the original radio.
Can you offer more details?
Posted: 11 Aug 2023, 18:34
by haithem93
SHeva4ever wrote: ↑25 Jul 2023, 19:39
I have the same problem, i have to turn on the dipped beam headlights for the daytime running lights to work
Did you fix the problem ?
Posted: 11 Aug 2023, 21:03
by SHeva4ever
haithem93 wrote: ↑11 Aug 2023, 18:34
I haven't fixed it yet. I've tried multiecuscan, alfaobd, delphi and wurth WoW. Nothing helped to enable it. I believe it can be done thru custom proxy, but I don't know which byte should be changed.
I also have my old cluster, so it is possible to install it, change this option using the menu and reinstall the TFT cluster. But I'm too lazy for it. So I drive on a low beam all the time. It is legal here in Ukraine.
Posted: 01 Oct 2023, 21:04
by Kareem
Would you please do that swap and tell us the byte to change, i am in the same situation now, however the old panel is completely dead
Posted: 08 Oct 2023, 08:18
by mariuscioby
Greetings. On my fiat 500 from 2008, I installed some dashboard clocks from 2022. I can't make any changes from the multiecuscan. The only error on the car is u1700-86. Dashboard language is locked to Danish. Can someone help me?
Posted: 17 Oct 2023, 20:23
by Pintobobster
WOW,
What a good thread,
Thought for sure I would see a post from Yani,
Looks to be MIA.
Read on here there was an update 4.8 I believe to correct the time/date flashing,
Any more information or anyone using the 5.1 see this correction for the flashing to be set.
