I guess is there a possible way to see if we can disable radio function in multiecuscan? maybe that would help ?
To disable the radio function, disconnect the radio and also the blue and me control unit and then do the proxy alignment.nufan0000 wrote:I guess is there a possible way to see if we can disable radio function in multiecuscan? maybe that would help ?
You should remove the ecu from the proxy configuration.
I don't have the radio anymore and currently have those Chinese Headunit with a Canbus in it. But is there a option in multiecuscan to disable Uconnect then for the Cluster? I think the mystery is that if we can disable Uconnect from the Cluster it will revert back? Do you know what will happen if you disable all the function like Blue and me and uconnect? Would the speedometer just revert back to factory? I am just askin as just wondering how I can revert the speedometer to factory without finding another car with uconnect.
I can not know, you have to try.nufan0000 wrote:I don't have the radio anymore and currently have those Chinese Headunit with a Canbus in it. But is there a option in multiecuscan to disable Uconnect then for the Cluster? I think the mystery is that if we can disable Uconnect from the Cluster it will revert back? Do you know what will happen if you disable all the function like Blue and me and uconnect? Would the speedometer just revert back to factory? I am just askin as just wondering how I can revert the speedometer to factory without finding another car with uconnect.
Hi Alex,
Can you post or PM a screenshot of your Custom Proxy data for the TFT graphics in your picture below please?
Grazie
Grazie
- IMG_9081.JPG (139.04 KiB) Viewed 20150 times
Of course!snowbound_sonic wrote:Hi Alex,
Grazie
I send you the 500 Abarth proxy code in which your tft was mounted!
Fiat 500 Abarth Restyling:
33 32 31 35 30 30 31 39 31 39 30 4F 55 54 50 55 54 44 4A 49 54 20 16 06 06 4F 80 00 04 10 00 00 00 09 00 00 04 10 00 00 00 91 C2 77 06 FE 00 1C C0 00 00 00 26 00 01 00 94 06 01 01 00 40 00 00 20 75 41 0A 0C 0D 01 80 2E 24 00 00 00 00 31 02 51 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 05 00 94 08 52 00 04 88 02 00 20 80 00 00 40 00 85 00 0F 00 00 00 80 05 00 C0 02 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
Let me know if you find the byte to configure the new tft graphics.
The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
I'll change that value on my custom proxy and see what happens.
This is not the secret of new graphics.snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
I have the bodycomputer of a 500 Abarth restyling experimental that still has the old graphics and the byte 65 is always 20.
alex-et3 wrote:This is not the secret of new graphics.snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
What happens if you change Byte 65 to the value 60 using the restyling BCM?
If I set it to 60, it's always the same as it was at 20 or 30.snowbound_sonic wrote:alex-et3 wrote:This is not the secret of new graphics.snowbound_sonic wrote:The most obvious difference I can see is Byte 65 has a value of 20 and we know that particular byte changes the graphics.
These trials, however, have always made them on the bench, not on the car.
