Page 2 of 5
Re: Retrocamera 500L e 500x
Posted: 17 Jun 2017, 13:09
by m.brignoli83
I know that with leonardoaccinni software you can enable the rear camera even if it is not prepared because the radio has the video input
Posted: 17 Jun 2017, 13:17
by alex-et3
m.brignoli83 wrote:I know that with leonardoaccinni software you can enable the rear camera even if it is not prepared because the radio has the video input
No, I have that tester, but if the radio does not have the hardware you can not enable it.
In your case, the only solution is the aftermarket interface.
Posted: 17 Jun 2017, 13:36
by m.brignoli83
Bad news.
Thanks :cry:
Posted: 11 Aug 2017, 17:01
by LWN500X
Hi,I tried to activate the retrocamera with blue adapter and gray adapter but during the alignment I get errors.
I used multiecuscan 3.7 REGISTERED.
My radio is Uconnect 5" Live - FIAT 334 VP2 ECE serial number 07356616890.
After finishing the procedure I find the total kilometers flashing in the car display.
My car is FIAT 500X 1.6 MJET 120HP CROSS version S1 - 02/2017.
Can setup\Proxy allignment procedure (334).
I enabled reaer camera and than i selected proxy allignment procedure.
I want know if is possible mount rear camera?
Please help me.
Loris :roll: :!:
Posted: 11 Aug 2017, 17:21
by alex-et3
LWN500X wrote:Hi,I tried to activate the retrocamera with blue adapter and gray adapter but during the alignment I get errors.
Please help me.
Loris :roll: :!:
Hi!
Your Uconnect if it is only radio does not support the rear camera.
Only the Radionavs support the retrofit
Posted: 11 Aug 2017, 20:42
by LWN500X
Hi!
Can you suggest me an appropriate interface?
Loris :roll: :?:
Posted: 11 Aug 2017, 20:51
by alex-et3
LWN500X wrote:Hi!
Loris :roll: :?:
I have never fitted it, you should ask who sells it.
https://www.car-interface.com/vendita/i ... riore.html
Posted: 18 Aug 2017, 12:17
by LWN500X
If I Purchase this Nav Uconnect?
FIAT 334 VP2 ECE DAB NAV RVC
Thanks.
Posted: 18 Aug 2017, 12:31
by alex-et3
LWN500X wrote:If I Purchase this Nav Uconnect?
Thanks.
Yes, RVC = Rear View Camera
If you want to operate the RADIONAV you need to enable navigation function on bodycomputer with Leonardo tester, or after you have done the proxy alignment does not engage more satellites.
In addition to run the Live services will have to do in fiat workshop the writing process of the frame number in RADIONAV.
Posted: 18 Aug 2017, 12:39
by LWN500X
I thank you, very kind, but too many things to do. :o :o :o :o :o
If you purchase a model: FIAT 334 VP2 ECE DAB RVC no NAV?
Thank you.
Loris :roll: :!:
