fia500
General messages
yuko1
fia500
Post by yuko1 » 07 Jun 2016, 15:36
CAN CONFIGURATION DATA:
6F 84 00 04 02 00 00 00 6F 84 00 04 02 00 00 00 43 04 00 00 00 00 00 00 01 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00
6F 84 00 04 02 00 00 00 09 00 00 04 02 00 00 00 6F 84 00 04 02 00 00 00 09 00 00 04 02 00 00 00 09 00 00 00 02 00 00 00
33 32 31 35 30 30 31 31 36 37 31 4F 55 54 50 55 54 2D 4A 49 54 20 14 07 31 6F 84 00 04 02 00 00 00 09 00 00 04 02 00 00 00 93 C2 75 06 F4 00 1C A0 AA 80 00 26 00 01 00 94 06 01 01 00 00 00 80 10 3A 41 0A 0C 0D 00 80 00 23 00 00 00 00 31 05 61 00 00 00 04 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 80 00 11
Body Computer Node (NBC)
Engine Control Node (NCM)
Electric Steering Node (NGE)
Dashboard Node (NQS)
Receiver Radio (NRR)
Brake System Node (NFR)
Climate Control Node (NCL)
Side Acceler./Yaw Node (NYL)
Airbag Node (NAB)
Convergence Telematic Node (CTM)
6/7/2016 4:31:22 PM
CONNECTED TO:
Fiat 500 0.9 Turbo TwinAir
Body Computer Node (NBC): EOL Ok
Engine Control Node (NCM): Ok
Electric Steering Node (NGE): Ok
Dashboard Node (NQS): EOL Ok
Receiver Radio (NRR): Ok
Brake System Node (NFR): Ok
Climate Control Node (NCL): Ok
Side Acceler./Yaw Node (NYL): Ok
Airbag Node (NAB): EOL Failed
Convergence Telematic Node (CTM): EOL Ok
EXECUTING ADJUSTMENT...
Auxiliary audio input
Old value: Not enabled
New value: Enabled
COMPLETED
Rear fog lights
Driver's side
Engine type
Knee guard (driver's side)
Old value: Not Present
New value: Present
COMPLETED
PROXI ALIGNMENT PROCEDURE
Writing to module: Airbag Node (NAB) FAILED! - Request out of range error
Writing to module: Convergence Telematic Node (CTM) SUCCESS!
FAILED TO EXECUTE
how configure airbag?
ion
Re: fia500
Post by ion » 23 Jan 2018, 11:40
hello,
i have the same problem here, i think the airbag was replaced and the product number is different. if you have any solution now please reply.
alex-et3
Re: fia500
Post by alex-et3 » 10 Feb 2018, 13:00
ion wrote:hello,
You have to buy the correct airbag control unit for your car
