Odometer at last DPF replacement
General messages
punzo77
Post by punzo77 » 01 Feb 2015, 21:08
hi, I apologize for the incorrect English, but I am translating with goole.
I noticed that after the reset of the service and that the oil change, now at last in the Odometer DPF replacement I view km oil change.
Odometer at last DPF replacement = 71940 km
Odometer from last oil change = 71054 km
When I did the reset oil change, I made the reeds RESET SELF-Learnt FUNCTIONS.
why the dpf is changed in those miles? should not indicate 0 km since it has never been replaced?
no way to fix the error?
Forse cercavi: non so se può servire, ma utilizzo il cavo odb con l'adattatore 3 sempre inserito
I do not know if you can serve, but use the cable with the adapter 3 odb always inserted
thank you
boch
Re: Odometer at last DPF replacement
Post by boch » 07 Feb 2015, 10:07
Everything is fine, i think. If your DPF was never replaced, value "Odometer at last DPF replacement" should be the same or similiar as Odometer.
