New Dash - Cornering / GSI / S&S symbol missing
General messages
addy75
Post by addy75 » 08 Aug 2014, 18:26
after changing the original dashboard with an dot-matrix-dash i miss the S&S symbols, the GSI - symbol and the cornerning light menu.
Is there any possibility to activate it these functions?
Is there any possbility to "reset" the dash to bring it back to the "brandnew" status?
The new dash is from 2011, my bravo sport is 2012.
If further information are needed i will do all to serve them 8-)
addy75
Re: New Dash - Cornering / GSI / S&S symbol missing
Post by addy75 » 11 Aug 2014, 10:44
*bump*
No answers? To diffculte question or no good enough explained?
YANI i count on your knowledge :D
Post by yani » 11 Aug 2014, 15:13
What was the original dash? Dot-matrix or not?
Did you do a PROXI alignment after the change?
addy75
Post by addy75 » 11 Aug 2014, 20:29
Hello Yani,
thank you for your reply.
The original was not-dot-matrix (the less nice) with cornering light / s&s / GSI.
Yes i did the PROXY alignment. Nothing changed
/EDIT
I missed to say:
The dash was already mounted on another bravo an aligned.
Post by yani » 13 Aug 2014, 06:02
Ok, then you can try the following: In PROXI settings set Display Type to Matrix/4 lines and do the PROXI alignment again.
Also, after finishing with the PROXI alignment, send me a report (from the red Send Report button in Multiecuscan).
addy75
Post by addy75 » 13 Aug 2014, 08:36
Hello Yani,
thank you. I will try it after my holiday.
I've never seen the PROXI - settings you wrote about but i'll look.
I will send you an report from the new dash and the original dash.
Thank you very much in advance 8-)
addy75
Post by addy75 » 02 Oct 2014, 13:54
yani wrote:Ok, then you can try the following: In PROXI settings set Display Type to Matrix/4 lines and do the PROXI alignment again.
Hi Yani,
i send you the report. I hope you find the reason, why it isn't working as desired :roll:
